dynoed sts kit today
Click here
Its spools nearly the same. Like has been said, a turbo that is that far from the heat source is going to suffer from lag, btw was that dyno with the meth injection??? I would love to see a dyno run showing the IAT's without the meth on....
Jose
-Geoff
turbotech kit with t76 = 5,100
sts kit is 3,800 + 500 methanol kit + 800 headers = 5,100
Also can anyone explain why his power curve looks like it was drawn by someone with parkinsons? Is that misfire? Surging? Lack of fuel? Too much Fuel? Inquiring mind(s) would like to know.
Thanks,
Rob
P.S. Great numbers!
I like how STS is thinking outside the box. They went their own way and have put a more reasonable pricetag on their kit than any other.
I too am curious to see someone push this kit to see if it will keep up with the big turbo kits.
Mike
also how much would the bottom end have to be built to handle this kind of power? i got about 108k on the engine with absolutely no problems. these seem like a great investment for a broke-*** guy like me
http://www.discountchips.net/2kss/vi...bolt1final.mpg
UPdate:
"The 93 Turbo Camaro went 600 rwhp and 723 rwtq at 12 psi today. Dyno graphs
will be posted on the site next week. Stock LT1 kit with GT67 turbo upgrade
and .96 A/R housing.
Later, Rick @ STS
now im not sure if the guy upgraded to a 383 yet or not. but thats pretty damn good."
Later, Rick @ STS
-Geoff
Also is that car lowered in the movie?
-Geoff
he should go low 11s according to the numbers of the other kits on the boosted list. that is if its drag raced, because you know, it's not a race kit.
Fo instance the T67 @ 12psi can flow a max of 60lbs/min which equates to about 550rwhp and the 60-1 numbers are also higher then the turbo can support for a specific pressure ratio.
No offense guys I have no doubts that your kit works but the numbers sound a little inflated. Kinda reminds me of when the QMP kit came out and we all know how that turned out.
