dynoed sts kit today
Old May 31, 2004 | 09:53 PM
  #61
White_Hawk's Avatar
Originally Posted by Excal
he should go low 11s according to the numbers of the other kits on the boosted list. that is if its drag raced, because you know, it's not a race kit.
Dude, save your excuses until after he goes to the track!
And if it is not a race kit, then what is it? Is there any other kind of turbo kit? Is it a towing kit or something? I am just asking because I don't know - oh wait, you're just messing with me, right?
-Geoff
Old May 31, 2004 | 10:26 PM
  #62
Excal's Avatar
It's the perfect towing kit, they have a rock clibing truck equipped with it, no over heating probs. but seriously STS billed it as a "street" kit
it's not an excuse, but if you figure a couple cars here dance around 1000hp flywheel hp and don't break into the 9s, even with conventionally mounted turbos, not to mention on superior ls1 cars, if this non-vented optispark car does go 10s some people Got Robbed. (is the pun intended?)
Old Jun 2, 2004 | 06:32 AM
  #63
BlackCamaroSS02's Avatar
Originally Posted by BlackCamaroSS02
DUDE does a LS1 sound similar to that? that car sounded awesome. I dont want the kit to be quite i need a loud exhuast. If it is quite how can i make it that loud. Mods are in sig
Also is that car lowered in the movie?
so no one has any info on that?
Old Jun 2, 2004 | 03:32 PM
  #64
BigPlanTransAm's Avatar
yes, the LS1 does sound like a V8. if you get a bov it will make a whistling noise when you let off, instead of the hard to describe sound it makes in the vid. if no bov you get the vid noise.
Old Jun 2, 2004 | 03:53 PM
  #65
Shinobi'sZ's Avatar
What good is a turbo kit if the size of the turbo or design only allows power upper-mid RPM or makes peak power and than drops off. I would rather see the run complete to 6200-6500rpms. Needs bigger turbos or exhaust back pressure addressed.
Old Jun 2, 2004 | 04:49 PM
  #66
black_knight's Avatar
The reason it works off the compressor map is because they are not using a standard turbo. It's a custom. The part you are using is just the housing. I forget which they are actually using... I read it on another board. Surely someone knows the answer to this?
Old Jun 3, 2004 | 03:12 PM
  #67
it is still pushing the efficiency range even with it being custom, i would love to see someone put a bigger turbo on there and see what happens.
Old Jun 3, 2004 | 04:08 PM
  #68
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
The T67 is not much different on the compressor map then the standard T66. The compressor wheel is only 1mm larger...hehe
Jose
Old Jun 3, 2004 | 04:55 PM
  #69
MYTURBOT/A's Avatar
Why would they use a custom turbo it's not like they are restricted by space?
Old Jun 3, 2004 | 05:00 PM
  #70
LS1TECH Sponsor
Not sure what is custom about it. Sounds like a regular T67 with a .96 A/R if I remember correctly.
Jose
Old Jun 3, 2004 | 05:06 PM
  #71
thats what i thought too, they use a custom turbo because of EGT's that far away from the headers. i would think a 60mm compressor would be a 60mm compressor but i may be wrong. and when i said bigger turbo i meant 76 or so mm's
Old Jun 3, 2004 | 05:11 PM
  #72
LS1TECH Sponsor
The only thing custom would be a small A/R on the 67. Not much else can be done...
Jose
Old Jun 4, 2004 | 12:21 AM
  #73
RICE ETR's Avatar
Turbo Addict
What i don't understand is how this kit can make more power with a turbo then the turbo can support according to there compressor maps.
Fo instance the T67 @ 12psi can flow a max of 60lbs/min which equates to about 550rwhp and the 60-1 numbers are also higher then the turbo can support for a specific pressure ratio.
I don't know what their correction factor was... but I do know that running straight methanol can give you a decent gain in hp....I have seen 10-15% gains posted on other boards in certain applications.
Old Jun 4, 2004 | 08:51 AM
  #74
F8L Z71's Avatar
12 Second Truck Club
we'll probably be dynoing my truck today for the first time with the STS kit on it. I still have the small exhaust housing on my GT35. I don't know the exact turbo sizing but on the unit in ink was 61mm to 68mm. The new housing will be a 91mm they said.
So we'll see if the power drops off hard like the others. I am pretty sure it will but not worried since the new housing isn't on yet. We will redyno with the new housing and post up to compare once it comes in.
Old Jun 4, 2004 | 08:52 AM
  #75
LS1TECH Sponsor
If I remember correctly Rob gained 50rwhp with just alky injection and 93 pump over his 93 and race gas mix at the same 11psi boost.
Jose
Old Jun 4, 2004 | 08:55 AM
  #76
F8L Z71's Avatar
Jose
I wouldn't doubt it. Race gas doesn't lower your IATs like Meth will.
Old Jun 6, 2004 | 03:30 PM
  #77
amacgt's Avatar
I finally got the 10psi graph emailed to me. If i email to someone can they post it for me? thanks
Old Jun 6, 2004 | 03:32 PM
  #78
frcefed98's Avatar
Sure, send it my way jsbird1998@comcast.net
J
Old Jun 6, 2004 | 07:10 PM
  #79
pacmantravis's Avatar
you can send it to me also. pacmantj00_2001@yahoo.com
Old Jun 6, 2004 | 07:59 PM
  #80
slyws6's Avatar
Hey guys I'm building my own similar kit but will be using a T70 and will be testing out a .81 AR and .96 AR housing on it. The kit will be really similar but custom tubing etc and the turbo will have it's own oiling system. I'll be making a skid plate for it as well which will also help keep water and debris from the road off of it. I'll keep you all posted as to what it does hp wise.
-Sly
