Efi source 3 bar map parameters
Old Sep 18, 2014 | 11:53 AM
oscs's Avatar
Default Efi source 3 bar map parameters
Does anyone have any specifics on this map sensor? I need the values for the dominator ecu
Old Sep 18, 2014 | 01:59 PM
denmah's Avatar
Moderator
same as every other 3 bar map
is it asking for overall and increments?
try 305kpa max
and 10.33 for offset
should have you close to atmosphere at key on, engine off
Old Sep 18, 2014 | 02:19 PM
wild1100's Avatar
Default question
Its not -10.33 offset. I thought it was negative
Old Sep 19, 2014 | 08:13 AM
oscs's Avatar
I forgot the specifics. I'll be playing around with it this weekend.
Old Sep 19, 2014 | 01:35 PM
denmah's Avatar
Moderator
yeah it all depends on what the ecu wants and how it works with it
for hp tuners you use 30x and 10 you skew them slightly with a weather station to match the pressure if you want to be absolutely perfect.
ive never set one up in the holley software
Old Sep 19, 2014 | 01:53 PM
oscs's Avatar
Originally Posted by denmah
yeah it all depends on what the ecu wants and how it works with it for hp tuners you use 30x and 10 you skew them slightly with a weather station to match the pressure if you want to be absolutely perfect. ive never set one up in the holley software
Yeah I figured you could get super detailed with it. Right now I have the sensor selected as factory GM. I'll report back when it's fired up.
Old Sep 19, 2014 | 01:59 PM
denmah's Avatar
Moderator
yeah if you choose GM 3 bar it will be fine
Old Sep 19, 2014 | 03:36 PM
stevieturbo's Avatar
Best way is to test with a mityvac or similar over the entire pressure range you expect to be using.
Ive seen some map sensors ( usually chinese ) that are miles off the correct scaling for a genuine unit.
If you check, you know it's right.
Old Sep 22, 2014 | 08:33 AM
oscs's Avatar
I ended up leaving it set to "GM factory" and it ran/idled fine.
Old Sep 22, 2014 | 12:44 PM
denmah's Avatar
Moderator
yessir, same specs as a gm3bar
Old Dec 29, 2014 | 07:04 AM
oscs's Avatar
Just an FYI for any future requests. I received an email from mike@EFIsource this morning. "Linear setting is 305 and the offset is 10.33."
