What is the best product to "glue" heads on??
I have heard that Hylomar is good. I have experience with copper spray, anything else? Hoping to keep it together this time and absolutely will be using some kind of sealant.
Thanks in advance,
Mike
There are a few solutions I've seen used in other engines that work pretty well.
Adding a reciever groove to the block or head and making a copper wire "o-ring" to cut into the MLS some helps create a tighter seal on the MLS (usually without loosing the seal on water and oil jackets).
There are different approaches such as the "pyramid ring" or "crush ring" gaskets that have a sharp stainless steel edge that cuts a groove into the head (crush rings are usually head and block) to create a tighter seal.
Mike
1.) Its ability to move as the block/head expand at different rates.
2.) Its ability to transfer heat between the head/block.
By using any type of sealer on the gasket you loose those benefits. GM even put out a service letter on this exact subject. In short, MLS should always go on dry.
Hundreds of us are doing it without an issue. You must have some sort of deck surface, or tune issue. The addition of Sealer won't help with that. I've pinged 29lbs a few times and never pushed a drop of coolant with the same studs and HG. Also ran 34lbs on my daily 4g63 setup with an MLS installed dry.
That being said, I know lots of guys that swear by the permatex spray mentioned above. In my turbo buick days we used a single SS "shim" head gasket and Dow Corning 995 structural silicone. It held up much better than the permatex FWIW. We used a small paint roller to apply it. The buick head gasket kits these days even come with that sealer.
http://rjcracing.com/product/head-gasket/
Good luck!
The only gasket I would try dry at this point, is the black Fel-Pro Permatorque. I heard you practically have to chisel that off of the block, it seals so hard.
Mike
12.0-12.5 AFR and 16* and 16lbs on C16. Melting plug strap as well.
https://ls1tech.com/forums/forced-in...ng-7-plug.html
Even when I first started out with LS motors and ran WAY too much timing, I never lifted a head, just butted rings and windowed a motor. If the LS9 gaskets are similar to the LS1/Ls6, I'd give the copper spray a try.
It has pushed water on 10* of timing and 12 psi at an 11.2 AFR, for example.
Oh, and I did not melt the ground strap. I removed the porcelain.
Although your first sentence in the post I linked was...
