Help me diagnose this :)
Old Oct 13, 2014 | 09:29 AM
607motorsports's Avatar
Default Help me diagnose this :)
Took the car out last Friday night for a large local meet and cruise. While making a 3rd gear pull the car felt normal, shifted into 4th and felt it start to miss so instantly let off only to see smoke bellowing out the back.
Luckily I was close to home so I made it back there quickly. There was zero loss in oil pressure, no oil coming out the exhaust or under the car, and do not see any sign of metal at all in the oil. But when you start the car it instantly smokes like crazy out of my catch can and there is a milky/sludgy oil in the can.
Thoughts? Ringland? Head gasket? I haven't done much to look the car over yet to be entirely honest and I had planned on doing a forged build this winter regardless so not the end of the world just looking for some insight on what you guys think I should expect to see when I tear it down
Old Oct 13, 2014 | 09:54 AM
yenkomike's Avatar
sounds like a head gasket to me. should find one steam cleaned spark plug if you pull them. or do a compression check.
Old Oct 13, 2014 | 11:41 AM
Agreed man that's my feeling as well, i'll have to start pulling plugs and checking it out more.
Old Oct 14, 2014 | 11:15 AM
stevieturbo's Avatar
busted piston or HG
time to pull it apart.
Old Oct 15, 2014 | 03:14 PM
I had planned on doing a full forged build on it this winter regardless so no big deal as long as it didn't take out a sleeve
Old Oct 16, 2014 | 03:47 PM
Tally TransAm's Avatar
cracked #7 sleeve would be my guess
Old Oct 19, 2014 | 06:13 PM
Oh man I really hope it's not the sleeve
Old Oct 19, 2014 | 09:35 PM
LT1RAY's Avatar
I'm going to guess a busted piston ringland on number 7.
Old Oct 20, 2014 | 09:13 AM
Old Geezer's Avatar
Water level is?
Pressure test the rad w/ the plugs out?
Old Oct 20, 2014 | 10:16 AM
I'm thinking it's a ringland for sure but the water level is down a few inches from normal. I haven't had time to start tearing it down yet but hope to start ripping into it this week.
Old Jan 19, 2015 | 06:18 PM
JAYSS10's Avatar
i cracked #7 sleeve in a 02 z28 what causes that, no power adder ran never over 6000 rpm not lean stock cam ,im lost also pistion busted to the top ring land there
Old Jan 19, 2015 | 08:15 PM
oscs's Avatar
Most common reason for #7 "cylinder" failure is heat. Those of you that had issues, were you guys running steam port plugs in the rear of the heads? If so I bet $20 that's your issue. I actually run 1* less timing in cylinder number 7 just for good measure.. Also I have a 4 port steam vent system.
Old Feb 7, 2015 | 06:48 PM
JAYSS10's Avatar
thanks for info so it is a problem ,l deff.,take your advise on timing im running e85 guess I figured that was keep it safe
