stock bottom end turbo 5.3 turbo timing table with holley hp, advise needed
If anyone can shed some light on how close/far off I am here that would be great... I am very very new to the turbo 5.3 game (my setup has been running for about a week now). Mainly, I want to know if this is a reasonably safe timing table (Holley HP), way too safe, not safe, any input welcome basically.
Here's the specs
L33 5.3, stock bottom end, head studs, LS9 head gaskets, LS9 cam, NGK TR6 plugs (checked gap but not changed from out of box), 91 octane, 8psi, 12.0 commanded afr.
I've made a 70% tps pull and it seems to run very well. I just want to make sure I'm getting the most out of it without pushing my luck on hurting this motor. I do not have knock sensors. I adjusted my timing table based off of one of the custom calibrations that holley had on the disc based off of information i'd found here. That is why at 150kpa I basically flatlined it at 18 degrees.
Again, I am going off what I've been slowly learning and I am very new to this stuff. I just want to be sure I don't make a mistake that could cost me greatly. Thanks in advance.
I don't see anything in there that could hurt you at 8psi but I would fill in the table above that just in case your car makes more boost for some reason. Just throw 12* or something like that in it above 8psi. Your timing table should resemble a stock engine until 100kpa. You have more timing at 120kpa than you do at 100. I'm at 28* at 100kpa and pull timing from there. Although 12:1 afr is probably okay at 8psi I target 11.5. Your wide band is averaging all 8 cylinders so I like to make sure the leanest one still has enough fuel. If you enable large table you will be able to fine tune it more. I wouldn't try to push the timing table unless you have a dyno or dragstrip available and some better fuel.
^^^agree with above. i think that on 91 its hight above 8lbs and you need to smooth the 80-140 kpa range some. make some pulls and check you plugs. I for sure would pull some out of the 180 range.
in windows 7 there is a utility that comes with the OS and its called Snipping tool you can choose the box you want to cut right on the scree and save it, or if you did an entire screen cap you could crop the image then to only what you want
there are tons of "snipping" tools out there varying in complexity
the win7 snip tool is my favorite as its small and works great
I can agree with not setting the world on fire, but the old N/A 406 felt nothing like this. To me, it's a monster right now. I wanted to get a few miles on it before winter to keep my motivation alive. Next spring I was planning on shooting for E85 and more boost. At this point, I can't fathom that feeling. It is silly fun right now....lol
Here's what I'm working with. She's heavy as hell but I plan on making it move out pretty well with more work.
woah woah woah. This is my timing table. I'm new to tuning as well but I thought my car was dialed in pretty good. It trapped 141mph and made almost 700rwhp.
I never even bothered increasing it because it ran good. I wonder if I am leaving a lot on the table
Its a LH6 5.3 (the one with 9.9:1 compression) so same as a L33. Im running an LS7 cam and ls6 intake
I tried messing with it on the dyno but unfortunately the car started spinning the tires on the dyno at that point so I just set it back to what it was originally.
It makes me want to increase it...because you guys are running 20% more timing which is pretty significant in my opinion
Im running 94 octane with methanol.
Your numbers are very close to what I run on 91 pump. I was at 14* at 170kpa. One more degree and I dropped 40lb/bls so I backed it off. That was with a little mpt70 on a cammed L33. I was at 28* until 100kpa then pulled it out a bit faster.You probably have a bit more room to go with your fuel but I would try it on the dyno or track. Maybe start adding in a degree above peak torque only to start.
