Merge functionality
Old Nov 20, 2014 | 06:55 PM
3 window's Avatar
Default Merge functionality
Hey guys, I'm workin on my hot side and fabbed up this merge. From here it'll go into a 2.5 elbow and into the turbo (t4 flange). What do you guys think? The joint is actually more centered, the pipe is tilted on the floor.
Old Nov 21, 2014 | 06:16 AM
LS1NOVA's Avatar
Why wouldn't it work?
Old Nov 21, 2014 | 07:30 AM
JoeNova's Avatar
Restricted User
I'm wondering the same thing. I've seen guys that stick welded together crimp-bent piping and used old fence posts as crossovers. If the exhaust flows through it and doesn't leak... its good to go.
Old Nov 21, 2014 | 08:03 AM
oscs's Avatar
That mere looks more than fine.
Old Nov 21, 2014 | 11:41 AM
3 window's Avatar
After it was together, I was concerned with gas flowing from one side to the other. Just me overthinking it! Thanks guys.
Old Nov 21, 2014 | 07:13 PM
93camaro_zzz's Avatar
Looks good to me.
Old Nov 23, 2014 | 10:30 AM
mufflerguy's Avatar
No problems with the fit, nice work. My only suggestion would be that they say you should have a reasonable amount of straight section before it actually enters the turbo. When its coming out of a turn and right into the turbo, there is a lot of turbulence, so you don't get as good a "push" on the impeller. Sometimes that's just not an option though. Here's how I did mine, but again, its not always an option depending on space and location.
Old Nov 23, 2014 | 05:10 PM
3 window's Avatar
I should be good going into the turbo. The elbow is roughly 8 inches away from the turbo itself. So this will give me a pretty good shot straight in!
