96 LT1 383 stroker paxton
Exhaust leaks are easy, tranny leaks should be too hard to figure out a solution.
Leaks on an LT1 (a boosted one especially) are not uncommon. Cleans the block down completely, then use some baby powder and run the car to trace down exactly where the oil leak is coming from.
As far as oil in the intake, if you have ever popped off any intake on an engine before you know they are not clean and have residue. Are you sure its oil?
Cars are like people, as they age and get older, it takes regular main trance to keep them healthy whereas when they are younger and more in their prime they can take a little more abuse without showing the signs of wear and getting older.
Your 96 Camaro is getting ready to turn 19 years old. Its likely going to need some TLC to get things back up to good shape.
It only takes a little patience to root out and resolve those 'little' problems, but leaks can cause issues. My wife's Malibu had an oil leak that turned out to be a simple valve cover gasket; maybe yours will be that easy too!
Good luck!
Additionally I just installed my boost gauge, the car sits at -13 vacuum but never goes over 0 when giving it gas, I think this leak may be a reason to rebuild the supercharger... but could it just be a simple waste gate problem?
Thanks for your replies guys!
And still not sure about why my blower really isn't making boost
It's vacuum side is about 13-15 and when accelerating it will just never go past 0.
