Bell Intercoolers
Old Dec 15, 2014 | 06:00 PM
Monte4ever's Avatar
Default Bell Intercoolers
I was just about to purchase a Bell horizontal 24x12x4.5 intercooler to replace my CXracing 4" intercooler but they list it at only flowing 729cfm. For the price I thought it would flow a lot more than that. From the flow numbers it doesn't seem worth the cost to change my CX unit. I may look into a vertical flow unit but really did not want to change out my piping. Does anyone feel that it would be worth changing.
Old Dec 15, 2014 | 10:01 PM
LASTLS1's Avatar
6 Second Club Moderator
Mine worked GREAT!!!!! Made 1000hp with it, temps get awesome
Old Dec 16, 2014 | 01:43 AM
Monte4ever's Avatar
I think I miss understood their CFM ratings. I believe it's 1 psi drop per 729 cfm. In that case this intercooler is exactly what I'm looking for cause at my power level I shouldn't lose no more that 1.5-2 psi.
Old Dec 16, 2014 | 01:45 AM
Monte4ever's Avatar
You're using a Bell horizontal 24x12x4.5 core?
Old Dec 16, 2014 | 08:43 PM
Monte4ever's Avatar
Straight from Bell Intercoolers is that there is only 1 psi drop per 10 psi of boost. So I should be looking at a 1.5 psi drop or less. They are VERY expensive though when you have them build you one. I almost said f@#! that lol. I see why people stick to the eBay cooler.
Old Dec 16, 2014 | 08:56 PM
LASTLS1's Avatar
Not now when I ran a air to air street driven. Ran 8.2's. Worked great!
Old Dec 16, 2014 | 09:50 PM
Monte4ever's Avatar
That's good to hear.
Old Dec 17, 2014 | 09:41 AM
rotary1307cc's Avatar
You will never be over 729cfm through core as it is
Old Dec 19, 2014 | 09:43 AM
Monte4ever's Avatar
At 15psi ????
Old Dec 19, 2014 | 11:36 AM
How big of motor and rpm?
Motor is a positive displacement pump. flow volume (cfm) doesn't change entering the engine aside from changes in VE
It is the density ratio that is changing from boost to Na
Take a 370 at 6500rpm and 85% VE. Motor will consume ~600cfm through the throttle body
Now take same situation at 15psi manifold pressure. Motor is still consuming same 600cfm through throttle body. It is just at twice the density
1200cfm entering the turbo..... Still only 600cfm through the ic and throttle body
Old Dec 19, 2014 | 02:40 PM
25thhawk's Avatar
What did Bell give you for a price? I have been looking at the same size unit, chiseled is around $1000 and treadstone is around $400
Ryan
Old Dec 19, 2014 | 03:30 PM
oscs's Avatar
How big of motor and rpm? Motor is a positive displacement pump. flow volume (cfm) doesn't change entering the engine aside from changes in VE It is the density ratio that is changing from boost to Na Take a 370 at 6500rpm and 85% VE. Motor will consume ~600cfm through the throttle body Now take same situation at 15psi manifold pressure. Motor is still consuming same 600cfm through throttle body. It is just at twice the density 1200cfm entering the turbo..... Still only 600cfm through the ic and throttle body
Great explanation. I knew I was condensing the air but figured it was actually flowing more CFM than its N/A counterpart.
Old Dec 20, 2014 | 11:10 AM
Monte4ever's Avatar
The motor C I is 403 with a max RPM of 65-6600.
Originally Posted by 25thhawk
What did Bell give you for a price? I have been looking at the same size unit, chiseled is around $1000 and treadstone is around $400 Ryan
$1250 with shipping and my end tank design.
Old Dec 20, 2014 | 01:46 PM
Monte4ever's Avatar
I just found a Garret 24x12x4.5 core for $450 and some weld on end tanks for $135 and it looks like they will fit my application. The core is rated at 950hp. If i could find someone here in MI to weld it up I would save possibly $550 with added labor cost. How does Garret compare to Bell?
