Turbo for a stock 5.3
And I would say a s366 is a little on the small side. You could easily reach your goals on the s475 t4 and still keep the boost down. If it were me I'd throw a cam in too while the heads are off
Anyway this should clear it up for u
http://www.himni-racing.com/turbocha...rbo-t4-turbine
Jack
If you go with a Borg Warner, get the $650 S475 with 83mm turbine. You might have to toss in an extra $150 or so if you want the T4 turbine housing. It'll run great on a 5.3 with plenty of head room.
https://ls1tech.com/forums/forced-in...ack-times.html
and then you insert a turbo to fulfill those needs
its like asking what kind of air conditioner do you need for your house
what size house? how cold or hot? how many rooms, etc
Displacement
RPM
Fuel Type
Horsepower Goal
That's all you need to size a turbo.
Jack
Btw what size wastegate and BOV would i need to run? Also what stall converter should i run for the 4L60?
Jack
What size intercooler do u guys think would fit behind my grille? Are those ebay intercoolers any good too? Here's my truck btw...Me and my buddy finished the swap at his shop back in July. Tons of room for a turbo under there!
