SDCE Track testing within......
Old May 30, 2004 | 12:24 PM
  #41
BIGBOS's Avatar
I just hope it stays consistent, I'm thinking kyle might have a boost leak somewhere.....he should be seeing more....but you never know....
I'm probably going to go with either a 3.4" or a 3.2" I will be talking to scott on monday more about it.....
Old May 30, 2004 | 12:50 PM
  #42
frcefed98's Avatar
I would talk to scott a lot more and tell him exactly what you are running. That might be a bit hard with how quick he talks but make sure he knows that you are running a 370 with some great flowing heads. Your small cam might actually help you with the boost you see.
I agree Kyle might have a boost leak. All my clamps were loose and I posted that in the update thread. I went over everything a milion times on my ATI set up to make sure everything was right. Too bad I forgot to fill the ATF huh I might go back to a mech boost gauge because this digi only tells you high and lo, it doesn't show if the belt is slipping like my old mech gauge did(needle hovering then sinking)
I hope he posts up some more info for us to see.
But be sure to talk to scott and let us know what he said. I pm'ed on fri night to ask them if I should be seeing this much boost....I am more freaked about that then anyone else could be.
Old May 30, 2004 | 12:52 PM
  #43
NA$TY-TA's Avatar
Originally Posted by BIGBOS
Any more suggestions on what size blower pulley I should try?
At least the 3.4" pulley..................... ill be posting more later.........
Kyle
Old May 30, 2004 | 12:59 PM
  #44
frcefed98's Avatar
Pm'ed you Buddy
Old May 30, 2004 | 01:02 PM
  #45
BIGBOS's Avatar
Yea, we talked briefly before, but I'll get more into detail about the motor......
I plan on throwing a griffin on the car if all goes well.......that might run me into fuel problems though......
Old May 30, 2004 | 01:05 PM
  #46
1QWIKZ's Avatar
i know i hardly post here, except only to fugg with kyle(dont worry kyle, i wont fugg with you today_). whats the max psi the ATI is setup for?
i am just asking because i have done the blower thing in the past and was disappointed with it. thats when i decided to go nitrous. but thats another story. i am interested in this tread so thanks in advance.
Old May 30, 2004 | 01:12 PM
  #47
frcefed98's Avatar
Max boost the D1-SC can put out is 32psi. On the LS1, I don't have an idea how much it can be made to squeeze out.
J
Old May 30, 2004 | 01:22 PM
  #48
BIGBOS's Avatar
I know SD's chevelle is putting down over 900 to the wheels with a D-1SC, I'm not sure of others out there who are putting it to the real test....
As soon as I get my pulleys I will put it to the real test
  #49
NA$TY-TA's Avatar
Thanks man......... you know im bumbed and almost ready to go the same way as you................ time will tell....... i dont really know the max someone has seen with this kit..... im sapposivley spinning mine at 51,000 rpms.......... 2 above i was before and seeing 11 psi before........ 7 now on the new motor....... steve called me on the way back and he told me about the little trouble he was having........ how much longer you got till yours is done?? Maybe i MIGHT go with a 3.2" blower pulley BUT i dont know........
Kyle
Old May 30, 2004 | 01:25 PM
  #50
NA$TY-TA's Avatar
FP stayed strong......... and it was only set at 56 psi and no boost ref. rising either..........
Kyle
Old May 30, 2004 | 01:26 PM
  #51
BIGBOS's Avatar
Thats good to hear, did MTI check over anything for leaks, etc?
Old May 30, 2004 | 02:36 PM
  #52
frcefed98's Avatar
Here is a few pics of the inserts in my tips...
It goes from 2.5in pipe to a 5/8 inch restrictor(opening on insert) with 13 pencil sized holes around the perimeter. I have one on each tip.
J
Old May 30, 2004 | 02:48 PM
  #53
BIGBOS's Avatar
Yeaaaaaaa, those need to go
Old May 30, 2004 | 02:54 PM
  #54
frcefed98's Avatar
I have one pounded out, working on the other.....I didn't think my lil stick welder did that good of a job
J
Old May 30, 2004 | 02:57 PM
  #55
BIGBOS's Avatar
Yea, those seem like a BIG restriction
Old May 30, 2004 | 03:16 PM
  #56
1QWIKZ's Avatar
Kyle
i think the reason you went from 11psi to 7 is because your heads and intake. you no longer have the restriction there so your psi went down. just like my ATI went from 17psi to 11 after a head and intake swap on my mustang. you pullied up to make up the difference? thats the problems with blowers, hard to tune and major belt slippage. but you will see that going the nitrous route isnt always easier. there is always gonna be a factor involved in making power in any kinda car. if you are thinking about selling the blower to go nitrous, i would advise you differently. you already have all the supporting cast(fuel system, low comp motor, heads,cam) it would cost more money to start all over. i would say get a turbo instead. you will never see belt slippage or psi lost. the turbo woulda "pushed " more air to make up your 4 psi drop. thats the beauty of turbos, not preset to a certain rpm by a pully. this is just my take on it, but good luck with whatever you decide.
ps..my car is about a month away from being done...but then again, thats what i said 3 months ago.
Old May 30, 2004 | 03:17 PM
  #57
frcefed98's Avatar
That's nothing look at them out of the tip.........what was I thinking
AWWNAWW HELL NAWW
Old May 30, 2004 | 03:30 PM
  #58
BIGBOS's Avatar
Damn Jeremy, those things are uuuugly.....
With Kyle's pulley combo he SHOULD for SURE be seeing more than 7psi.....if not then the belt is slipping or there is a boost leak.......with a 7.25" crank pulley and a 3.7" pulley he should be around 13-14psi at least.....I was setting mine up to max out the D-1SC blower and that is with a 3.2" blower pulley....
But.....
When I saw Jeremy make 16.2psi at 7900 ft, that had me thinking on what that would turn into at sea level, and he has the same pulley combo as kyle....
I'm still deciding on 3.2" or 3.4" either will put the D-1SC close to MAX impeller speeds...
Old May 30, 2004 | 04:39 PM
  #59
NA$TY-TA's Avatar
I was thinking that route........ Everyone of my friends want me to give up on this blower setup............. I have almost 6K in just the blower alone...... i would like to see what this kit is capable of, but i believe it was never designed to make the power we are wanting from it........ if you are wanting 7-8 psi of boost and about 440-460 rwhp on a stock motor and be happy with it this kit is for you....... im not.... i am wanting to see what others see and do first befor ei just totaly give up.........
Kyle
Old May 30, 2004 | 04:40 PM
  #60
NA$TY-TA's Avatar
Bos, we checked and on the last pull on the dyno i blew the rubber piece that goes from the plenum into the TB........ who knows.....
Kyle
