853 vs 799 heads
One more question.. say if I decided to spend money and pick up 317 heads, would the money be better spend porting the heads I have now?
317s are more pump gas friendly and flow better than the 853s. On top of the port work, you'd need chamber work as well.
Will drivability suffer? Is it much harder to get a tune with e85? Thanks for the responses guys! It sounds like I may just run the heads I have now. Im still doing more research on my setup as it will still be a few months before its ready to run. I still have to build my t56 as well.
1.Most responses on the 5.3: Its cheap. Run it till it pops and get another for $300.
My take: They are not cheap where I live.. 5.3's are going for $1K used. 6.0's are $1300+.
2. They will take more boost and are stronger in stock form.
This goes back to the fact they are not cheap where I live. If I just upgrade the rods and possibly a set of forged pistons with ARP fasteners throughout, is there any reason I cant make the same power with the less weight of the aluminum block?
Thanks for the help guys, I like to ask a lot of questions Lol.
For your power levels, buy a set of good valvesprings and throw the turbo on it. Leave the heads alone and spend the money on head studs.
