Gen 4???
Old Feb 28, 2015 | 01:50 PM
1970 nova's Avatar
Default Gen 4???
Hey guys, I think it is, just want to be sure. It is a 2005 6.0 LQ4 with 100k from a van. I picked it up a few months ago and just took it apart. It has flat top pistons so I know it is a LQ4. If it is a gen 4, does that mean it has floating pins also? I have a BW 480 billet, so do I have a little more room for power output? If you guys could take a look and let me know if different pics are needed. Thanks in advance.
Old Feb 28, 2015 | 02:39 PM
66Chevellelq4's Avatar
I might be mistaken, but im almost positive all LQ4's came from the factory with dished pistons. Flat tops came on the LQ9's
Old Feb 28, 2015 | 07:30 PM
Project GatTagO's Avatar
2005 would be Gen III...
Where is your cam sensor? 24 or 58 tooth reluctor?
Andrew
Old Feb 28, 2015 | 07:55 PM
JoeNova's Avatar
Restricted User
Pop off the oil pan. One quick peak underneath and you'll know for sure.
I've had an 05 5.3 with gen 4 rods before. I don't know when they started putting them in the 6.0s
Old Feb 28, 2015 | 10:55 PM
baggins's Avatar
Those are the beefy rods but am lq4 has dishes. Lq9 is flat tops
Old Mar 1, 2015 | 12:39 AM
Mongoose350's Avatar
If it's an 05, then it's a Gen3.
Flat tops came in the LQ9, that's really the only differance between the two, I think. Same heads (317), but the LQ9 has a higher CR.
Old Mar 1, 2015 | 12:58 AM
LT1RAY's Avatar
Those are gen 4 rod's.
Old Mar 1, 2015 | 03:52 PM
willizm's Avatar
Yep some 04's and all 05-06 lq4's are gen3 motors but with gen4 rods/Pistons. Got an 05 lq4 in the garage as a backup motor.
Old Mar 1, 2015 | 07:52 PM
1970 nova's Avatar
Andrew
Cam sensor is in the back of the engine near the oil pressure sensor. It is a 24 tooth reluctor.
So, I guess I have a LQ9. No big deal, but wanted lower compression for the boost, but I'll live with it.
Since, it has the gen 4 rods, does that mean that it has floating pins and not pressed?
Old Mar 1, 2015 | 09:21 PM
2muchboostNY's Avatar
Or you could sell it to me and pick up an LQ4 .
Old Mar 2, 2015 | 05:03 PM
1970 nova's Avatar
UUUUhhhh yeeeeaaahhhh, let me think about that.
Old Mar 3, 2015 | 06:01 AM
95bowtie's Avatar
Jesus the miss information in here is strong.......
Anything LS that is 05+ has the beefier rods.
Also 05 and 06 certain vehicles had 24x reluctor with the cam sensor in the front timing cover. Just because the cam sensor is in the front cover doesn't mean it is 58x always.
Regardless that wasn't op's original question I don't think. I want to say it was just about the rods and whether or not he can safely run 800whp through it instead of 650-700 that a gen lll will do.
