Help.....problem with lowering my compression.....
Old Mar 19, 2015 | 09:32 AM
LS6427's Avatar
Default Help.....problem with lowering my compression.....
So here's my deal: I really do not want to change my pistons.....
I had my AES 390ci built with Flat top pistons. I want to use a single PT88 turbo.
My engine info and planned parts:
Iron LQ9
4.030" bore
3.825" crank
6.125" rod ((1.180 pin height))
LS9 .051 gaskets
74cc chambered heads
Flat Top pistons
9.225 deck height
The compression calculator at http://www.eaglerod.com/....IF I DID IT CORRECTLY.....says 10.28:1 compression.
I'm trying to get it to 9.8:1.......
How thick can I go on the head gaskets ((Brand and part number)) and still have the gasket be very strong and reliable.......? That the only place I see any possible wiggle room to lower cr any more.
I know 10.28:1 cr is fine if I use full time E85....but Id rather not if I don't have to.
Thanks...
Old Mar 19, 2015 | 10:19 AM
Forcefed86's Avatar
If you have good deck and head surfaces cometic can make you a custom head gasket to hit most any compression you want, there is no limit really. Very common for the import crowd to run 3.5+mm thick HG's (.138" thick). I believe they sell a cheaper .070 shelf LS gasket as well.
Old Mar 19, 2015 | 10:28 AM
stevieturbo's Avatar
How thick are the piston crowns ? Could they be machined ?
Likewise can chambers be opened out more ?
Cant say I've ever seen anyone using a gasket more than 2mm thick, and even that's rare.
Old Mar 19, 2015 | 10:54 AM
Forcefed86's Avatar
Wouldn't need that thick of a gasket to drop a half point of compression.
3.5mm is common in the BMW turbo crowd…
http://www.jegs.com/i/Cometic+Gasket...FZSKaQodNWoAwg
I ran a 3mm thick gasket on my Sc300 2JZGE setup as well.
Old Mar 19, 2015 | 06:10 PM
LS6427's Avatar
Ok....I did the compression calculator again using .070 gasket......it dropped me to 9.87:1......
That should be good......
Again...if I am figuri it all out correctly with calculator. I used the one here:
Old Mar 19, 2015 | 06:11 PM
LS6427's Avatar
I was also wondering that......because when I enter 78cc chamber volume and .051 LS9 gasket........and everything else I listed the same......that also drops me to 9.86:1
So can a 74cc chamber head like the AFR 245 be ported 4cc more in each chamber.......?
Old Mar 20, 2015 | 07:26 AM
LS6427's Avatar
Would this be the proper gasket to use for 4.030" bore....?
http://www.netgaskets.com/COMETIC_He...%20c5751-b.htm
Is .070 thickness perfectly fine for 18-20 psi.......???
Old Mar 20, 2015 | 10:30 AM
00duvall's Avatar
No u need atleast.030 bigger than ur bore
Old Mar 20, 2015 | 10:56 AM
LS6427's Avatar
My bore is 4.030".....that gasket is 4.060".....
.030 bigger......
Is that not correct....?
Is a 4.080" gasket better....?
Old Mar 20, 2015 | 11:07 AM
00duvall's Avatar
My bad i thought u were saying the gasket was 4.030. That one will work. If that price is for one u can get cheaper thru vendor.i will send u a pm
