Huron v1 dp
Old Mar 24, 2015 | 08:17 PM
a-low's Avatar
Default Huron v1 dp
Just finishing up the turbo install but for the life of
me can make the dp work. If i get it close enough to the turbine outle theres still a gap on the v bandflanges
and the outlet is right were the starter goes. In other words i wont be able to bolt the starter. Im running a tubular k if that matters. Did i get a bad dp? Did anyone encounter this problem? Heres a few pics.
Old Mar 24, 2015 | 08:23 PM
a-low's Avatar
Ive searched other threads and noticed other dps end below the starter where the oil sensor
would be and this one doesnt.
Old Mar 24, 2015 | 09:03 PM
LT1RAY's Avatar
What's keeping the downpipe from being rotated down?
This is about the best picture I have:
It does look a little short based off of this picture.
Old Mar 24, 2015 | 09:57 PM
ujslost2's Avatar
I had the exact same problem with my v1 downpipe. Had to end up cutting it and reweld it, to make it work.
Old Mar 24, 2015 | 10:57 PM
a-low's Avatar
Cant rotate it anymore because it hits the motor mount. Dp does seem shortt compared to pictures ive seen.
^ujlost The reason i ditched the magnum and went with the on3 was because that i didnt have to modify anything lol.
Old Mar 25, 2015 | 10:17 AM
Superman09's Avatar
LS1Tech Sponsor
I have not received any contact from you at all. A simple e-mail to me would answer any and all questions you have! Shoot me an e-mail direct to huronspeedproducts@gmail.com and I will get you all set-up!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 25, 2015 | 01:28 PM
a.white86's Avatar
Any issues you have with it, I feel sure they'll jump right on fixing any issue you have.
My customer service has been perfect so far, although I haven't started my install just yet.. Will in the coming weeks. But email them is your best bet and they'll take care of ya I bet.
Good luck with your build man!
Old Mar 25, 2015 | 04:07 PM
a-low's Avatar
Thanks Jon. I know youre a busy guy, I will email you.
