Help with sluggish running and back fire.
Old Apr 3, 2015 | 12:02 PM
onesloGTO's Avatar
Default Help with sluggish running and back fire.
Hey guys,
I have been working on the car for about a month now. It started running pretty poor. Really sluggish when accelerating. And it back fires quite a bit, even at idle. I've replaced plugs, and fuel filter. I've also tested the plug wires. All is good there. Recently started tuning to 91 octane, as it was e85 before I bought it. Fuel pressure was high, so adjusted down to around 57. 80lb injectors.
Tuner said that the tune is close and there is no reason it should be running this way. Could a vacuum leak cause this? Bad fuel injector?
Old Apr 3, 2015 | 12:33 PM
93camaro_zzz's Avatar
It seriously sounds like it is running really rich, but hopefully that would be something your tuner could tell. Definitely wouldn't hurt to do a boost leak test, but I don't think that is the problem.
Old Apr 3, 2015 | 12:42 PM
onesloGTO's Avatar
I'm not even using boost right now. Just trying to dial motor in.
Would running rich cause my symptoms?
Old Apr 3, 2015 | 06:13 PM
Absolutely it could. If you had a bad injector, you would be able to pick that up on the wideband. Do you have a wideband in the car?
Old Apr 3, 2015 | 06:27 PM
onesloGTO's Avatar
Yes I have a wideband. How do I tell if an injector is bad. Or possibly a coil pack?
Old Apr 3, 2015 | 07:51 PM
If injector is stuck open, car will read that it is running rich. If an injector is not opening you could usually tell that by a certain primary not heating up, or checking out spark plugs. For coil packs, the easiest thing I have found to do is to sway out coils with someone else that is a known good. Fastest and easiest way to tell.
Old Apr 3, 2015 | 07:53 PM
onesloGTO's Avatar
So what afr would I be looking for to notice a bad injector?
Old Apr 3, 2015 | 10:03 PM
6669camaro's Avatar
Read the spark plugs. If they are all very black then it's running rich. If one looks real wet and smells like gas then you may have a bad injector on that hole. To test the coil packs just hook up a spark tester to the end of the plug wire and set the gap at about an inch, the coil should be able to easily jump the gap. Can't jump it then the coil is bad.
Old Apr 3, 2015 | 10:34 PM
onesloGTO's Avatar
Ok, I just put the plugs in about 3 weeks ago and pulled them again to do a compression test recently. At that time they were all very black.
Old Apr 3, 2015 | 11:21 PM
6669camaro's Avatar
The motor must be running very rich for some reason. Lots of possible causes like tune, map sensor, maf sensor, coolant temp sensor, motor not warming up properly, ect.....
If you have access to a scan tool you really need to read live data and see what the computer is seeing.
Old Apr 3, 2015 | 11:26 PM
6669camaro's Avatar
Has it been retuned since you switched back to 91? If it is still putting in the same amount of fuel through the injectors as it was with e85 that could be why it's running so rich. E85 motors run much richer then 91 motors.
Old Apr 3, 2015 | 11:29 PM
G8One2's Avatar
Sounds like a restricted exhaust to me..... Might want to try attaching a vacuum gauge to the intake manifold, should have 18 to 22 in.-Hg of vacuum or more at idle, then as it runs it will slowly drop if the exhaust is restricted. Disconnecting the exhaust and retesting can verify.
Old Apr 4, 2015 | 01:18 AM
onesloGTO's Avatar
I have HP Tuners. I can post my last log and tune if anyone would like to have a look.
Old Apr 4, 2015 | 01:19 AM
onesloGTO's Avatar
The exhaust dumps right behind the passenger door.
Old Apr 4, 2015 | 07:07 PM
onesloGTO's Avatar
I decided to check to see if I could pull a code one more time. I got a P0121 code.
Could this be my problem?
Thanks guys.
Old Apr 4, 2015 | 09:53 PM
onesloGTO's Avatar
Also getting a P0122 code.
Old Apr 5, 2015 | 10:16 AM
RonSSNova's Avatar
If the stoich in the tune was not changed from E85 value (9.77) to gas (14.7) it will be incredibly rich. You haven't mentioned what your Wideband is reading?
Old Apr 5, 2015 | 10:45 AM
onesloGTO's Avatar
Wideband is reading around 14 to 15.
Old Apr 5, 2015 | 12:02 PM
If the wideband is reading 14 to 15, then I would trust the wideband. It may be a different issue besides fueling.
Old Apr 5, 2015 | 12:35 PM
onesloGTO's Avatar
What do you think about the TPS? From the symptoms I've read on it, that's what is going on with my car.
