F1A verse the F1A-91??
LS1Tech Sponsor
The F-1A 94 is the one to go with, if you want an upgrade over a standard F-1A. It's good for around an extra 150 hp over a standard F-1A, but is softer down low. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Yes I would, unless it's a light car that already has too much low end power. Thanks. Bob
__________________
UNDER PRESSURE MOD
That's not my car... it's full weight, plus the blower, plus the intercooler etc. So I'm figuring the 416ci ls3, plus the f1a, should make for some nice midrange torque. I'm using a 4.00" head unit pulley with a 7.65" crank pulley. No clue how much boost that will make.
LS1Tech Sponsor
__________________
LS1Tech Sponsor
Correct, you'll have to fab one, I'd use thin wall alum tubing. Bob
__________________
LS1Tech Sponsor
On my 408 with AFR 225 heads and my blower cam, I saw 18 psi with a 3.90 blower pulley and a 7.65 crank pulley. Bob
__________________
LS1Tech Sponsor
To determine the impeller speed, the following formula is used:
Maximum impeller speed = crankshaft pulley diameter (N1) divided by supercharger pulley diameter (N2),multiplied by the step-up ratio (4.10 for the P-series/D series - 5.40 for the F series), multiplied by engine rpm at redline.
An F-1A is good for 74,000 rpm. Bob
__________________
LS1Tech Sponsor
Don't really know as it had a glide with a 5000 stall. No meth. Bob
__________________
LS1Tech Sponsor
You're welcome. 3.90 should do it. Bob
__________________
i ideally want the F1A-94 but if it doesent fit without standing the radiator up and needs a fabbed inlet hat im debating wheather or not to just stick with the standard F1A..... if you think it will fit in direct replacement to my D1sc i'll get it...
