Issues to resolve before play-time!
Old Jun 4, 2004 | 01:33 PM
Black LS1 T/A's Avatar
Moderator
Default Issues to resolve before play-time!
I finally got a couple of street tunings going.
Issue I had to fix: pulley and belt alignment had to be addressed when I put the Superdamper/ATI CP and 8-Rib setup on. I think I have that worked out, now.
On to my current issues to work on.
It's almost as if the fuel is mostly concentrated in the passenger-side rail when I first go WOT, but soon it is concentrated mostly in the driver-side rail as I move.
Check out the EFILive logs below.
So:
Issue 1: I think I may have to do a parallel setup; Y the fuel flow.
LS1-Speed thought the rails would be large enough that it just would not matter.
Even though I appear to be getting more volume, I am not getting it evenly.
Issue 1: I see some belt slippage because the 3.3" SC pulley is too small to tighten the 40.0" belt any more, but too large for the 39.2" and 39.3" belts I've managed to find. The perfect belt would be 39.5", but I can't find that in an 8-Rib... not so far.
Issue 2: I have to find the right combination of Inj Flow Rate and fuel pressure (while maintaining LTFT's at 0) and RPM per PE to get enough fuel and keep the Inj Duty Cycle between 80% to 90% max. O2s were as high as .980 in some places when I first started tuning!
.905 with my cats has been about 11.7 AFR at the dyno
.920 to .930 has been about 11.2 to 11.4 on the dyno
93 Octane, 0.1 to .8 KR
I did these on a roll since I still have my P285/40 ZR17 Nittos (not DR) on
60 PSI base fuel pressure.
I saw about 13 PSI boost
1st Gear Run
Code:
RPMs	MPH	O2L	O2R	IPW	IDC
2643	11.2	894	933	12.90	 28.4
3332	19.3	911	938	15.30	 42.6
4299	27.3	920	951	18.80	 67.2
5099	32.3	916	755	22.90	 97.2
6021	37.9	933	894	20.90	105.0
6592	41.6	929	760	19.30	106.0
6911	43.5	924	877	18.30	106.0
6991	43.5	924	764	18.20	106.0
Separate 2nd Gear Run
I saw only 10 or 11 PSI here.
Code:
3094	34.2	903	929	14.30	36.70
3740	36.0	920	955	16.30	50.70
4142	39.8	929	964	18.20	62.80
4330	44.7	938	968	18.50	66.90
4721	51.6	938	898	22.40	87.90
5001	55.3	942	903	22.50	93.90
4915	55.3	946	929	22.40	91.80
4893	53.4	946	903	22.40	91.20
4812	51.6	946	885	22.30	89.30
4802	53.4	942	898	21.90	87.70
5026	57.2	938	699	22.60	94.60
5220	60.3	951	729	22.70	98.70
5523	63.4	942	933	22.30	103.00
5616	64.6	942	911	22.00	103.00
5825	68.4	942	777	21.10	102.00
5945	69.6	933	833	20.80	103.00
6078	70.8	938	894	20.50	104.00
6140	72.1	929	877	20.30	104.00
6216	73.3	929	720	20.00	104.00
6259	74.6	929	707	19.80	103.00
6445	75.2	924	807	19.60	105.00
0.0 KR
62 PSI Fuel base pressure.
I saw close to 14 PSI boostin first gear and
it dropped to 10 PSI boost in 2nd
1st & 2nd Gear contiguous run
Code:
2958	23.6	924	964	14.10	 34.70
4318	27.3	942	972	17.50	 62.90
5154	32.3	929	885	22.40	 96.30
6110	37.9	942	851	20.60	105.00
5708	65.9	951	755	21.80	103.00
5760	66.5	946	842	21.50	103.00
5832	67.7	942	924	21.20	103.00
5859	67.7	946	929	21.20	103.00
5823	68.4	951	964	21.10	103.00
5896	68.4	942	877	21.00	103.00
5931	68.4	942	920	20.90	103.00
5857	68.4	946	794	20.90	102.00
5882	68.4	942	803	21.00	103.00
5846	67.1	938	933	21.00	103.00
Old Jun 4, 2004 | 01:39 PM
Moderator
Also, anyone know who makes a 39.5" 8-Rib belt?
Old Jun 4, 2004 | 01:45 PM
LordFlux's Avatar
What was the cause of the alignment issues and how did you fix it? I ask, because my SuperDamper just arrived today and the 8-rib pullies are sitting on the shelf in my garage.
Old Jun 4, 2004 | 01:50 PM
Moderator
The 8-Rib Idler is very wide. It was touching my alternator belt.
I shimmed the bracket out by two or three small washers and that made the belt walk off the SC pulley. I shimmed the SC pulley on the D-1SC and that lined it back up.
I also ground the width of the idler pulley down to get more safety in case some flexing of components created a problem. There's still plenty of surface area on the idler pulley to handle things.
Of course, that does not mean you will have alignment issues. Every car seems to be a little different.
Hope that helps.
Old Jun 4, 2004 | 01:53 PM
kp's Avatar
kp
What diameter is the ATI 8 rib crank pulley Mike? I think I may go with that setup (between that and an ATI damper/SDCE setup) want to stay NHRA legal and thats the last thing left..
Old Jun 4, 2004 | 01:56 PM
BIGBOS's Avatar
Glad to see you are making some progress, I haven't heard from you in a while, are you using that RR pulley you got from me?
Old Jun 4, 2004 | 02:18 PM
Moderator
kp - I believe it's 7.5", but I'm not sure.
BigBos, yep. I skipped the 3.6" and went straight to the 3.3". I think a 3.20 pulley MAY have gotten me over the belt hurdle of using a 39.2" Gatorback. The idler adjust is right at the stop once the belt stretches out on a 40.0"
Old Jun 4, 2004 | 02:19 PM
BIGBOS's Avatar
Try grinding out a little extra room in the slot so you can push down a little more
I did it in the opposite direction for the Cogs
You will know when the belt is slipping with the RR's becuase they will EAT the ribs off the belt and you will see most of it on the blower
Old Jun 4, 2004 | 02:25 PM
MIGHTYMOUSE's Avatar
i would swap o2 sensors to see if that lean side stays where it's at or moves with the sensor. you should have certainly had some detonation if some of those numbers were legit.
Moderator
Thanks for the tip.
Maybe I'll see if grinding at the top of the slot will let me put the 39.2" belt on.
It will be considerably more difficult doing that to the steel bracket than the aluminum one, though.
Old Jun 4, 2004 | 02:28 PM
BIGBOS's Avatar
Yea, if needed take it to a machine shop and have it punched out.....I aluminum one with diamond cutters, still took a while.....
S_J_H's Avatar
Black LS1 T/A, you need a wideband to tune properly IMO. I always log my wideband and have seen my factory o2's read .890 when the wideband shows 10.2 A-F! The wideband will respond very quickly showing an erratic A-F curve while the stock o2's just stay at a sort of flatline.
When you log a wideband along with the stock o2's you'll see how inaccurate the stock o2's really are.
So I would seriously consider at least borrowing one while you tune the beast.
Old Jun 4, 2004 | 02:31 PM
Moderator
No detonation. With 93 Octane at 10 ~ 13 PSI, I've cut the timing back considerably:
Code:
TPA	LOAD	GEAR	RPM	MPH	Tmg	KR	 O2B1	O2B2	IPW1	IDC1	fMAF
100.0	 74.9	1st	2958	23.6	14.5	0.0	924	964	14.10	 34.70	8759
100.0	100.0	1st	4318	27.3	11.0	0.0	942	972	17.50	 62.90	10725
100.0	100.0	1st	5154	32.3	10.5	0.0	929	885	22.40	 96.30	11082
100.0	100.0	2nd	6110	37.9	10.5	0.0	942	851	20.60	105.00	11515
100.0	100.0	2nd	5708	65.9	10.5	0.0	951	755	21.80	103.00	11410
100.0	100.0	2nd	5760	66.5	10.5	0.0	946	842	21.50	103.00	11410
100.0	100.0	2nd	5832	67.7	10.5	0.0	942	924	21.20	103.00	11495
100.0	100.0	2nd	5859	67.7	10.5	0.0	946	929	21.20	103.00	11477
100.0	100.0	2nd	5823	68.4	10.5	0.0	951	964	21.10	103.00	11495
100.0	100.0	2nd	5896	68.4	10.5	0.0	942	877	21.00	103.00	11543
100.0	100.0	2nd	5931	68.4	10.5	0.0	942	920	20.90	103.00	11495
100.0	100.0	2nd	5857	68.4	10.5	0.0	946	794	20.90	102.00	11477
100.0	100.0	2nd	5882	68.4	10.5	0.0	942	803	21.00	103.00	11495
 36.9	100.0	2nd	5846	67.1	10.5	0.0	938	933	21.00	103.00	11358
Old Jun 4, 2004 | 02:33 PM
S_J_H's Avatar
right now your injectors are 100% static on the top end.
Old Jun 4, 2004 | 02:37 PM
Moderator
Right... I intend to increase the base pressure of the regulator.
But, like I said, .905 with my Cats was about 11.7 or so AFR on the dyno, so if that follows, I MAY also have room to lower PE/RPM.
BIGBOS's Avatar
Time for some moto's or the 72lbs that A&A sells
Old Jun 4, 2004 | 02:40 PM
Moderator
I thought of doing that, but notice how it starts higher on the passenger side, then shifts to the driver's side?
Old Jun 4, 2004 | 02:42 PM
Moderator
I want to.
I won't run it down the track until I get to a dyno.
I just need some numbers before I go there.
Old Jun 4, 2004 | 03:48 PM
i would still swap them to see if the trend follows the bank or the sensor.. only 10 minutes work
my set up still runs the rails in series with -8 line.. no noticeable a/f difference bank to bank up to where they pushed it at tubotech.
once i calculated that the fuel flows at 3 ft/second if you y'd them, and that would be 6 ft/second for the first one if you ran it in series.... compared to the 14 ft/ second that the same amount of fuel would have to go through stock lines to get the same flow.
from that i decided that it was not necessary for me to run them parralel.
Old Jun 4, 2004 | 04:42 PM
Moderator
Maybe I just need new sensors.
Or maybe, as was already stated, they are just useless to look at at WOT.
