Twin 255s not enough anymore, what should I go with for a pump?
What fuel? You should beable to make 1000 no problem on reg gas with twin 255's. I have.
Else two 340's or 400's should give more or do 3 255's. I run 3 now and should be over 1100-1150 now and looking for another 100
With the 255-340 stuff it depends on fuel pressure. They drop off in flow alot after 60 psi. If you have to run 20 psi or more to reach 1000 whp then keep base fuel pressure lowwww like 38-40. Large supply line -8 to -10 to get the volume up at lower pressures. I made 1009 sae thru a th400 on 64 psi total fuel pressure with two 255's. May have had more in it. 340's should do 100-150 more at similar pressure
Why don't you get a Kenny bell boost a pump... He sells one for dual pumps... You should get over 750 LPh on 17.5 volts...
Go to his website and see.. They are making 1000 rwh on stock set ups... Before you do anything you should visit his site on this .
http://www.kennebell.net/KBWebsite/C...elpumptech.pdf
