Spark plug wire help
Old Jun 17, 2015 | 03:44 PM
cherp22's Avatar
Default Spark plug wire help
Was going to run the stock wires with the heat shield but the header doesn't help that happen. I was looking for a set of wires with possibly a 90* plug boot and the factory coil pack end. MSD makes the custom bend ones which suck, ran them on my bbc's, taylor makes some inexpensive decent wires but they are 180/135 etc. Sorry if this has been covered didn't know if I just needed to order a full set and buy a set of 90* boots separate and change them out. Thanks
Attached Thumbnails Spark plug wire help-img_20150507_210747_zpsupwxejub.jpg
Old Jun 17, 2015 | 03:57 PM
6669camaro's Avatar
I've used Taylor universal BBC wires, they have a 90 boot on them then just bought a pack of the Taylor ls1 coil pack boots and made my own set. I think I ended up having like $65 or so into everything
Old Jun 17, 2015 | 04:00 PM
6669camaro's Avatar
Edit that. They were moroso universal wires.
Old Jun 17, 2015 | 04:02 PM
schaef_12's Avatar
I just went through this exact same thing. I spent big $$ on the msd wires and was not happy with them. I popped the hood on our 2007 Chevy 2500 with the 6.0 new body style and it had factory wires with 90 degree spark plug boots. I ordered a replacement set for that exact vehicle and the wires work great with my upside down truck manifolds since the 90 end on the plug keeps the wire nice and tight to the head.
Old Jun 17, 2015 | 04:10 PM
cherp22's Avatar
Good info! I work at a GM dealer so I may look into those
Old Jun 17, 2015 | 04:24 PM
cherp22's Avatar
Grabbed one for a 08 2500 hd out of the parts dept lol, going to give it a try. Has a 90* on it, pretty long tip to the 90* hope it clears haha
Old Jun 17, 2015 | 06:06 PM
schaef_12's Avatar
They should. Mine are aftermarket, but the factory ones looked like the boot was a bit more compact then the set I have.
Old Jun 17, 2015 | 06:41 PM
SPRAYED 01's Avatar
Get gm wires or spend a lot of money on granitelli or firecore. The msd, taylor and other after markets don't snap on the plug very nice. Take them off a few times and you never get a good feeling that's its on all the way.
I run factory truck wires with 8-900whp turbo setup.
Old Jun 17, 2015 | 06:58 PM
forcd ind's Avatar
I used the MSD wires on mine, I needed one tight to the head to clear the downpipe-they were tight and perfect-one thing you do have to be careful on the coil, make sure its all the way on or it will slide off-listen for the click
Old Jun 18, 2015 | 02:02 PM
cherp22's Avatar
No dice on the GM wire, they come out too far to the 90*, guess I will be working on making a set unfortunately. Need a conventional style 90* plugs end with the ls coil pack end
Old Jun 18, 2015 | 02:16 PM
schaef_12's Avatar
I think your stuck with the msd build your own ls wires then.
Old Jun 18, 2015 | 02:25 PM
cherp22's Avatar
I believe so, oh well wouldn't be the first thing on this car that didn't work how I wanted it to right?
