60# Siemens Deka Injectors & Turbo
I just got finished with my turbo setup.... On3 no AC 76mm kit. Will the 60# Siemens Deka Injectors be more than enough for me to make good power for my setup??
-01 5.3 iron block
-aftermarket fuel rails
-on3 76mm kit
-ls1 intake
-btr stage 3 turbo cam
-243 stock heads
-.650 PRC springs
-7.4 pushrods
-01 5.3 iron block
-on3 76mm kit
-ls1 intake
-243 stock heads
-.650 PRC springs
-7.4 pushrods
Yes those will let you make decent power unless you plan on using e85. The rule of thumb for gas is you need a lb/hr of fuel for every hp. Obviously fuel pressure, fuel type and application (ex.boost) are big factors here too. 60s can get you to 550ish I think.
