Major Problems with car!
Old Jun 6, 2004 | 12:52 AM
U-Luze's Avatar
Default Major Problems with car!
Help I took my WS6 to the local 1/8 mile track and it only ran a 7.83 at best at 94 on a 1.90 60'. It will not get into boost or do anything in low gear. The previous owner said he could do 1.50 60's footbrakeing. And Ive personally seen the car run 10.30s in the mid 130s. Could the tune be that bad off where it wont do anything now? Or the converter be bad, on the transbrake it wouldnt even leave hard. The air was pretty good tonite so i dont think that was it. It runs like a bastard when it hits 2nd gear on the highway, it just pulls very hard. So what gives help me out.
Old Jun 6, 2004 | 01:18 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Does it run strong thru the gears but not off the line?
Maybe the TPS went bad, I'd swap it from another car.
Old Jun 6, 2004 | 01:27 AM
Rob Raymer's Avatar
Yea..either that or the muffler bearings. Or maybe he should just start replacing sensors one by one until it's miraculously fixed.
Personally it sounds to me like it's too rich down low, making it hard to build boost off the line. Which could be in the tuning, but who really knows without more information.
It could also be pulling timing on the line due to either real or false knock. That will KILL power.
Or one of a hundred other things.
If I'm not mistaken, doesn't that car have a wideband? If so, what was the A/F at the line and after it cleaned up going down the track?
Old Jun 6, 2004 | 01:34 AM
LS1Tech Co-Founder
Ummm whatever Rob.
When Scott posted the same symptoms before I suggested he look at the TPS readings. I saw car a few years ago do the same thing, car took off like crap and then was a rocket in higher rpms, bad tps. Not saying that this car has it but I don't think that Scott changed the tune on the car this year.
Old Jun 6, 2004 | 01:36 AM
U-Luze's Avatar
Rob i tried to reach u on ur cell tonite to ask u but couldnt get an anwser, I want to buy the E-dist box and other box this week and get tuned so this thing will really move. But it moves on in 2nd gear. I have no idea what the car has tuneing wise. They said it was spitting fire out the tail pipes when i was doin my burnout. This thing is just a dog right now and I really like to get it all lined out. Thanks Justin
Old Jun 6, 2004 | 01:39 AM
U-Luze's Avatar
Yea john thats exactly what it does takes off like a turd and kicks *** in 2nd and 3rd gear. I can take the tps off my camaro to see if it works. Which one is it, one sensor on top or the bottom one?
Old Jun 6, 2004 | 02:06 AM
Rob Raymer's Avatar
I was in Bowling Green all day today and my cell doesn't get service there.
Spitting flames out the tailpipes is DEFINITELY rich. Could also be as simple as needing a new set of spark plugs. Or a TPS
Old Jun 6, 2004 | 02:16 AM
U-Luze's Avatar
Ill look at the plugs tommorow. Do u have the all the stuff i need to go full standalone in stock Rob?
Old Jun 6, 2004 | 02:18 AM
Rob Raymer's Avatar
Yes I do.
Old Jun 6, 2004 | 02:23 AM
U-Luze's Avatar
Can u get to the car this week to install and wire it up for standalone and tune?
Old Jun 6, 2004 | 02:38 AM
Rob Raymer's Avatar
I seriously doubt it. We are SLAMMED right now. Give me a call Monday at the shop so I can check the schedule.
I'm going to bed now...
Old Jun 6, 2004 | 09:44 AM
2001WS6Vert's Avatar
Just plug a scanner in to look at the T.P.S. data, its easier than changing it. Somewhere around 1 volt at idle and it should slowly go up consistantly until its around 5 volts at WOT. You would most likely get the service light and a code if its bad.
Old Jun 6, 2004 | 01:23 PM
U-Luze's Avatar
Thing is i dont have a scanner or autotap. I was just gonna swap sensors out from my other car and see if it helps out any. Im not sure which on the TPS is on the TB. The one on the top or the one on the bottom? Thanks
Old Jun 6, 2004 | 03:59 PM
LS1Tech Co-Founder
Well the TPS is the black sensor not the chrome one.
Old Jun 6, 2004 | 05:56 PM
Got Me SOM's Avatar
i'm with rob and its your tuning, not the tps sensor. if cars were that easy to troubleshoot online i'd be rich.
Old Jun 6, 2004 | 06:57 PM
White_Hawk's Avatar
Doesn't that car have a FAST? I have never tuned one but I know they have a built in scanner that should log the wideband too. You have a laptop? You should ahve it tunning - especially if you just got the car.
Does anyone else notice how posts get hostile when a certain person is in them? I can almost see that big shoulder chip down in Indiana from here...
-Geoff
Old Jun 6, 2004 | 07:12 PM
Black LS1 T/A's Avatar
Moderator
You need a way to scan your car ASAP. I would not DREAM of running these cars with FI and no way to monitor things.
Old Jun 6, 2004 | 07:43 PM
U-Luze's Avatar
I didnt not get the fast software with the car. It was suppost to me mailed to me. So no way for me too look. I was told there was no changes in tuneing since i seen it in Bowling Green, only changes for the car was a griffen FMIC. And thats not gonna hurt it. I just dont understand why it wont run like i seen it run.
Old Jun 6, 2004 | 07:50 PM
Ken G's Avatar
You might want to try giving the Cartek (maybe even the Eastside) guys a call. They know that car very well and may be able to give you some advice.
Old Jun 6, 2004 | 09:19 PM
LS1Tech Co-Founder
We can email the FAST software if you want, let me know what email addy, it come as a zip file.
You can see the AF real time on there.
