05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs
Old 11-11-2015, 11:34 AM
  #141
Forcefed86's Avatar
Late sub. for power numbers. Looks great!
Old 11-11-2015, 01:33 PM
  #142
Moderator
denmah's Avatar
Old 11-11-2015, 01:34 PM
  #143
Moderator
denmah's Avatar
im unsure if this 7875 is any better than the 7665 even though it should be, they feel like the same turbo lol...
i only want 600 ish, 700 tire would be nice as that would be very fast with this 3200 lb truck lol
but honestly itll get kicked out with 3200lbs and 550whp anyway
Old 11-12-2015, 08:46 AM
  #144
aggie91's Avatar
Awesomely Sloppy!
Old 11-12-2015, 07:01 PM
  #145
rpturbo's Avatar
So what happened to running this on a factory ecm? I thought that was the original plan? Looking great though!
Old 11-13-2015, 01:56 PM
  #146
Moderator
denmah's Avatar
i weighed in and wanted to run a gen3 computer, not a newer ecu, so most of my stuff wouldnt work anyway, i figured, while i was at it, why not wire in boost ****, traction control, and some other features etc
Old 11-13-2015, 01:59 PM
  #147
Moderator
denmah's Avatar
pulled the stock rear last night
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-wjnp8sg.jpg
welded new perches on the cut down 8.8 rear
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-gv7wr1t.jpg
slammed it home
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-uqyinvf.jpg
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-594q61s.jpg
Old 11-13-2015, 02:50 PM
  #148
7 Second Club
Rich Halsey's Avatar
Is the narrowed 8.8 close to the stock Colorado rear width?
Old 11-13-2015, 03:52 PM
  #149
Photochop's Avatar
This may have been covered before, but are you gonna run a Caltracs style rear traction bar setup on those leafs? Lookin good man!
Old 11-14-2015, 12:55 AM
  #150
Moderator
denmah's Avatar
yes and yes
Old 11-14-2015, 01:33 PM
  #151
UNDER PRESSURE MOD
The Alchemist's Avatar
Very cool progress... We'll have to talk tomorrow about what it takes to mod a Ford 8.8 to work in an f-body with the torque arm and keeping traction control.
See you tomorrow.
Old 11-14-2015, 11:30 PM
  #152
Moderator
denmah's Avatar
pulled a throttle cable out of a 01 blazer and installed it, clipped right in to stock truck hardware
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-prxmetq.jpg
drilled a nice hole
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-t7amwgg.jpg
pedal looks stock!
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-h8putno.jpg
self tappers and a travel limiter made out of the latch support i removed for the intercooler
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-iosrg9i.jpg
flipped the brakes around to the right sides today ( lower and too close to the leafs)
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-a35i8di.jpg
rear bolted in and im ready to measure for a driveshaft
05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs-oixgeg3.jpg
Old 11-15-2015, 12:54 PM
  #153
dirtylark71's Avatar
best places to scrounge up a DBC throttle body, platforms to look for at the junk yard? Going to scavenge one this week
Old 11-15-2015, 09:15 PM
  #154
Moderator
denmah's Avatar
99-03 trucks, tahoe, etc
Old 11-15-2015, 10:05 PM
  #155
tonypaul's Avatar
great work matt, your going to be doing major burnouts real soon.
Old 11-15-2015, 11:03 PM
  #156
Photochop's Avatar
See you tomorrow.
There's tons of guys in the KS/OK/TX region running 8.8s fabbed up for fbodys. I have one for my car - came in another I bought a while back and I swapped it before selling to run in my build. It's a 8.8 center section with about 4" of original ford axle tubes, then a donor 10 bolt is used and the axle tubes/ends are used and welded to the ford tube ends. A torque arm mount bracket is welded to the housing. Mine has an eaton posi, I'm putting 3.27 factory ford gears back in it (3.73s in it currently) and it has 4 channel backing plates and stock 4 channel axles in it. I don't have a need for the 4 channel stuff because my car is a 3 channel, but I may try and tap the housing for the stock 3 channel sensor, and ditch the stock axles for some nicer moser pieces. I'm sure you can find a shop in your area that could help you out with the fab work, its pretty simple really.
Old 11-16-2015, 07:48 AM
  #157
Moderator
denmah's Avatar
measured for a driveshaft and gave the spec's to my driveshaft guy! he built the one for the white fairmont.
got the shifter linkage tacked in, this thing might be moving under its own power by the weekend
Old 11-16-2015, 09:17 AM
  #158
That thing is going to haul the mail! Napa parts truck, express delivery
Old 11-16-2015, 10:15 AM
  #159
UNDER PRESSURE MOD
That's what I'm looking for. Something on the less expensive side, as spending ~$3000 for a rear is just not going to happen.
Old 11-16-2015, 11:40 AM
  #160
Blackbird-WS6's Avatar
look up "tnt fabrication" on FB. they build them for fbodys. they have a coupe diff levels to suit needs.
Quick Reply: 05 colorado SBE 6.0/C480/4l80e 9.78@143 foot brake 3850lbs
