I am having twins
20150319_185520 by Tom Fiddler, on Flickr
20150817_123716 by Tom Fiddler, on Flickr
20150817_123641 by Tom Fiddler, on Flickr
20150817_123705 by Tom Fiddler, on Flickr
20150817_123609 by Tom Fiddler, on Flickr
20150817_123438 by Tom Fiddler, on FlickrCombination Patio, Elevator and Loading Dock !!
20150817_123917 by Tom Fiddler, on FlickrOutside TV mount
20150802_113549 by Tom Fiddler, on Flickr
20150802_120123 by Tom Fiddler, on Flickr
20150819_185835 by Tom Fiddler, on Flickr
20150819_192846 by Tom Fiddler, on Flickr
20150819_192856 by Tom Fiddler, on Flickr It has been about 20 years since I have welded aluminum and it may show.
Got the cold side done yesterday
20150822_112359 by Tom Fiddler, on Flickr
20150822_134525 by Tom Fiddler, on Flickr
20150822_135419 by Tom Fiddler, on Flickr
20150822_204633 by Tom Fiddler, on Flickr Should be making passes in a couple of weeks. I have to remove the F body pan and modify the stock pickup to move it rearward. I add a baffle for braking. With anything that has a 60' of 1.45 or better it will start to uncover the stock setup.
Been there done that
FWIW If you have standard volume factory oil pump (not the DOD pumps on the new engs) You can run 6.5-7 qts of oil in the Fbody pan without pickup issues. I had a years worth of 1.3x 60's with the wheels up and the bearings all looked like new. Installed a high volume pump and I had issues, overfull or no. I dropped in the improved racing baffle and it took care of my issues.
I run a stock (non DOD) pump. The problem with overfilling the oil is that on the launch the extra oil is up in the crank. I have some screen shots of data before and after the pick up move.
Take an F Body pan, put 5 quarts of water in it and then tilt it up at 45 degrees. The same thing happens at 1g.
What ever works for you is great. I fought this battle 4 years ago and know what works for me.
We had a debate on windage issues on one of the other sites. To the point where filled the car up with the suggested 5.5 Qts logged a mild 9lb pass leaving with no boost. Then added 1qt and logged another pass. There was no noticeable performance loss I could measure. Slips were nearly identical.
I then pulled the pan and filled it with 5/6 qts of water. The oil level was just below my first turbo drain in the photo with 6qts. (I run the larger drain up front now. Aft drain is plugged.)
Then I installed the pan jacked my car up level with the first/lower turbo oil return line uncapped. Added 6 qts and started the car. Then added oil until it started to dribble out the drain. I was able to run just a hair under 8qts of oil. So the oil level drops roughly 2 qts with the engine running. Took the car track again with 8qts in it. Same MPH, nearly identical slip.
I realize oil sloshes aft and I’m sure there are windage losses. But nothing like an overfilled GEN1 SBC.
5qts
6qts
Here it is starting to dribble out at 8 qts, engine running.
The only change (besides leaving on the brake) in the second one was with the pickup moved rearward.
I have no hard data on performance with the extra oil, My weird brain just does not like that.
Set up and working.
This thing is pretty cool. I can easily change the throttle opening to dial the car down.
Also will be able to tailor the pedal to throttle opening to make it drive around nice
