I am having twins
Old Oct 11, 2015 | 01:01 PM
  #61
T.Fiddler's Avatar
I like the fitting !
I test flowed some $32 Ebay Bosch 044 copies. Buddy of mine got 2 of them for his Turbo 6.0 build. One of those pumps 5lbs per min at 71psi. (My Holley pumps 6lbs.per min)
May try his next outing.
Bad Apache
I need a quiet pump for when I go get Ice Cream in this thing!
Old Oct 11, 2015 | 10:09 PM
  #62
T.Fiddler's Avatar
Just thought I would post a track pic for no reason. I have a video of the second pass but they started the track blower beside my buddy filming so the shaky vid will give you a headache.
20151010_142350 by Tom Fiddler, on Flickr
Old Oct 11, 2015 | 10:23 PM
  #63
Forcefed86's Avatar
Looks great! If you ever want to sell it give me a shout! Tough to find a streetable car that light that will take big power.
Old Oct 12, 2015 | 09:56 AM
  #64
spray280's Avatar
Thats crazy!! At 5 lbs I'm still at 28* on 93. Start the ramp down right after.
Let me see if I have my 5.3 global on this pc, I'll email it to you to take a
look at.
Old Oct 12, 2015 | 11:22 AM
  #65
T.Fiddler's Avatar
look at.
Was certainly playing it safe. Wanted to be sure if the boost or lambda got out of control on the track I did not hurt it.
My goal is a 5.80 in the 1/8 th. I am pretty sure that will happen.
Old Oct 12, 2015 | 11:28 AM
  #66
T.Fiddler's Avatar
I will keep you in mind if that happens. It keeps getting fatter with the turbo install it is up to 2400 lbs going down the track.
Old Oct 16, 2015 | 10:56 AM
  #67
Fahrenschnell's Avatar
Do you mind posting a link to the turbo and turbo system parts you used? I am thinking of a very similar setup on my Chevelle.
Thanks
Old Oct 16, 2015 | 11:54 AM
  #68
T.Fiddler's Avatar
Thanks
Sure I will get a link list together tonight.
Old Oct 16, 2015 | 12:38 PM
  #69
T.Fiddler's Avatar
Forgot to post the waste gate install.
20151016_130824 by Tom Fiddler, on Flickr
Cool dual pump fitting from AeroFlow Performance Products. They are in Ozzy land $35 each I believe. Clamp is from Ebay and luckily had the right spacing for the fittings
20151016_132503 by Tom Fiddler, on Flickr
Old Oct 16, 2015 | 06:20 PM
  #70
spray280's Avatar
Thats a nice setup!! Are they 044's? I've been thinking of doing that
& ditching my noisy Fuelab pump.
Old Oct 16, 2015 | 06:54 PM
  #71
T.Fiddler's Avatar
Those are $32 knock off 044's. Flow results are post #61. I will get some more flow numbers with both running.
Old Oct 16, 2015 | 07:01 PM
  #72
T.Fiddler's Avatar
Turbo major part links.
Waste Gates
http://www.ebay.com/itm/321413801940?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Turbos
http://www.ebay.com/itm/170717412795?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Headers
http://www.ebay.com/itm/261569230635?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Turbo adapters. Not sure about THIS price I paid $29.95 each.
http://www.ebay.com/itm/161141320531?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Oct 18, 2015 | 10:48 PM
  #73
Forcefed86's Avatar
Have a link to that AeroFlow Performance Products fitting? I couldn't manage to find it on ebay?
Old Oct 18, 2015 | 11:37 PM
  #74
T.Fiddler's Avatar
I may have received bad info. I will check tomorrow with my friend, but they are listed here on the Aeroflow site.
https://www.aeroflowperformance.com/...af939-08-10blk
Old Oct 19, 2015 | 06:52 AM
  #75
Forcefed86's Avatar
What voltage were the knock off 044’s tested at?
If your going with 2 I used the cheap china AN "Y" fittings and push lock AN6 B-nut fittings. I'd throw at least a -8 feet though. This setup made about 600whp on e85. Harbor freight tripple splitter is still cheaper.
$10ea
http://www.ebay.com/itm/8AN-8-AN-8-M...bueCdg&vxp=mtr
http://www.ebay.com/itm/6AN-6-AN-6-M...1VmQTg&vxp=mtr
Old Oct 19, 2015 | 01:30 PM
  #76
T.Fiddler's Avatar
$10ea
All my tests are done with engine running, measuring from the fuel return at the rear.
13.5 volts.
My fuel system is all -8 to and from the regulator.
Old Nov 3, 2015 | 09:02 PM
  #77
T.Fiddler's Avatar
Small update. Tested the 2 044 copies and now pumping 9.5 lbs per min.
Upping the boost to 8 lbs and heading to the track this Saturday.
Old Nov 6, 2015 | 07:38 PM
  #78
T.Fiddler's Avatar
Traction Control wired and ready.
I am looking for a 5 in the 1/8
Old Nov 7, 2015 | 04:34 PM
  #79
T.Fiddler's Avatar
5.93 @ 118 mph 1.37 60 ft.
8 lbs boost
I like it !!
Old Nov 7, 2015 | 04:47 PM
  #80
3pedals's Avatar
Can't wait to see how that light little machine of yours responds to 18psi !!!
