I am having twins
That will change later this year. I have Santuff struts, front brakes and spindle mount Weld Magnums here waiting to go on.
Willwood rear brakes and Hawk DR-97 pads have been doing the job for 5 years.
Light cars are a wonderful thing !
Going to add external waste gates. Just thought I would give an update.
Disconnected the actuators today and was still headed to 15 lbs in about 1.5 seconds.
It runs over my 80 lb injectors at 10.69 lbs. I am moving the fuel pressure to 5 bar.
I am pretty sure 38mm WG's will do the trick if I get them in at the angle I want.
Yes I run at Mason Dixon mostly.
I would have been making passes by now if the boost was under control.
Lon
I have 2 38mm WG's coming. Thanks for the tip.
Bad Apache
I will let you know when I go. Gates should be here this Friday or next Monday.
20151001_113257 by Tom Fiddler, on Flickr 4200 converter is stalling at 5250 on the brake.
Took a little ride today and it is pretty stout. It gets under boost RIGHT NOW!
Will need a larger fuel pump but will be heading to Mason Dixon Saturday for some testing.
Timing was at 20 degrees under boost and Lambda target was .830 (8.0 afr on E-85 scale)
I may add another pump but would rather just run one.
Very happy with the test.
Can't beat multiple 255's (GSL392) for price vs performance at $96 each shipped with fittings. Run 3 of them with a 3 way pneumatic HF fitting and you'll have a quiet 200 gph pump for about $300. I made roughly 600whp on e85 with 2.
