single or twins for 1000 rwhp?
Price wise, I'd say there is really very little difference
At 1000whp, a pair of On3 76mm turbos will get you there for $700. Big singles will work, but to save money you'll likely be stuck with a T6 turbine.
There are pros and cons each way, there really is no universal answer.
Sometimes finding room for a big single is hard....as is finding room for a downpipe. So two smaller units is just easier.
Some who go nuts with twins, or tubular manifolds in general can leave the engine by with terrible access for simple things like plug changes....worth considering when you design.
Cold side plumbing with either, probably less of a concern as both should be fairly easy
But actual cost of parts etc...there really wont be a huge difference.
Many can use truck manifolds, so no cost difference there. hot/cold pipes, really wont be a huge pile of difference there either, maybe a little more fab with twins.
Turbos, such a wide range of prices, there is no simple answer there, but yes two of anything will cost a little more.
But thousands ? ....doesnt really make a lot of sense, depending on the level of kit of course.
But in the same logic you could say a V8 has 4 more cylinders that could fail vs a 4 cylinder car.
And no, there should be no diffculty tuning either.
There really isn’t that much added costs on twins. Other than another turbo really. You can get away with 2 smaller wastegates vs buying a 50-66mm gate that will run almost double what a 38-44mm’s would run.
I have debated twins many times and may still go that route to make it a more snappy bottom end car. What I like about twins is they almost seem simpler to package. Generally you are dealing with 2 smaller turbo’s opposed to one massive T6 flanged….well assuming you want a full exhaust and don’t plan on dumping out the front bumper.
In the 1000-1100whp range I would probably look into some Borg S366's or something. Proven reliable turbo, cheap to find as well. That’s assuming you will have some cubic inches pushing them. But they are on the larger side for a T4 67mm. You could run some cheap On3’s but I wouldn’t expect amazing reliability. They may be I dunno, lots on here seem to use them but at the end of the day it’s a china turbo. I run a China GT45 and it seems to be fine but it’s also a budget build stock 5.3L. Turbonetics seems to have an awesome warranty plus a pretty tiny and easy to package as well.
Jay
My 69 camaro has twins on it. I like the simplicity of the single personally but both work great.
https://www.turbobygarrett.com/turbo...between_turbos
