TC78 Replacement
Old Sep 13, 2015 | 02:08 PM
Black_Sunshine_99's Avatar
Default TC78 Replacement
I need some ideas for potential replacements for the Turbonetics TC78. It has to have the same external dimensions so I don't have reconfigure the cooling system. Can anybody give me some ideas? I'm thinking about a PT7475 but it's a street car so some something that'll spool quick but still make power to 6000-6500. Any help would be greatly appreciated. Thanks!
Old Sep 13, 2015 | 02:19 PM
stoverz28's Avatar
I assume you have the 7875 and not the older 7868 right?
Old Sep 13, 2015 | 09:27 PM
Negative ghost rider, I have the 7868 which seems to be choking out around 5,500 rpm. Get's there super fast but plateau's really hard.
Old Sep 14, 2015 | 12:37 AM
NemeSS's Avatar
How much have you made w the tc78 full trim?
Old Sep 14, 2015 | 06:47 AM
yenkomike's Avatar
yes how far have you pushed that tc78. I ran a tc78 on my 6.0 with a .96 housing and it ran 10.50s in my 3500# car. at 10# boost. there is no dought that I could have broke into the nines with it at a few more #s boost. it was a little restrictive upstairs but the fast spool will get the car moving out of the hole.
Old Sep 14, 2015 | 08:08 AM
69-chvl's Avatar
yenkomike now that you've had some time with the new turbo how would you compare the 2 turbos overall for a good responsive street car?
Old Sep 14, 2015 | 08:33 AM
2000GTP's Avatar
I was curious, are you using meth at all or just 93 pump gas? I just purchased the Huron kit with the TC78 and am curious what the limitations of this turbo will be and how much boost I can push without the use of meth.
Old Sep 14, 2015 | 04:57 PM
Tally TransAm's Avatar
i went 136+ mph @ 3600# and did 610 rwhp at 14.5# on a TC76 .96 AR maxed out. power just flat lined at about 5400
swapped to a 1.15 AR when I did the 4L80 and the power carries much better now. only have an eight mph comparison but went 106 mph with the t56 and .96 AR and 111 mph with the 4l80 and 1.15.
The new 7875 are the closest but are still larger so if clearance is ultra tight you will need to modify
Old Sep 14, 2015 | 05:13 PM
HolyShiznit's Avatar
7475 is a great budget alternative. I had it on my first set-up and now my friend is using it. He did 690 or so at 20 psi through an auto, 28's, and 9", on a Thompson 5.3, SAE. Little sucker can make some power.
Old Sep 14, 2015 | 05:24 PM
Superman09's Avatar
LS1Tech Sponsor
When you say cooling system, are you referring to the turbo also being water cooled? If so that is something to consider as Precision only offers Oil-Only. Let me know and I can get you into an excellent drop-in upgrade for the very best price!!!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Sep 14, 2015 | 05:52 PM
It pulls harder than hell to right about 5400 then slows waaay down. I'm also running full exhaust and the pipe going from the bell-housing area to the trans tail-shaft is compression bent and horribly done. I'm just running straight 93, no meth and the turbo is just oil fed. I'm already running a 1.15 AR housing too, its a divided housing and my hot side flange is undivided so I don't know if that makes a difference. I'm only running 6 lbs. right now and the way it's acting I would not feel comfortable putting the 10 spring back in. The turbo sits about 3/4" away from the radiator so a larger compressor housing is out and I'm not standing up the radiator. I'm definitely installing a cutout under the driver floor board but a couple of my buddies don't think that'll help but I want it anyways lol. The turbo only has maybe 1,000 miles on it and its a ceramic ball bearing unit so I'm wondering what I could get for it.
Old Sep 14, 2015 | 06:16 PM
Superman09's Avatar
LS1Tech Sponsor
Shoot me an email to: huronspeedproducts@gmail.com
I can get you exactly what you need!
__________________
Old Sep 14, 2015 | 07:04 PM
Thanks for the offer Superman but I don't have the coin to drop on a new turbo. I think I'm going to try and sell this one next month and see what I can find on the used market.
Old Sep 14, 2015 | 07:10 PM
yenkomike's Avatar
the tc78 is a better spooling street turbo. all things equal going from my tc78 to my s480/83/t4/1.25 . at the track with exactly the same tune it runs the same numbers. 10.50s at 130. now when I turn it up the 480 really brings it.
I did everything I could to make the same runs with both turbos.
93 no meth
11* timing
5500 shift point.
same launch 1.6 60' ect. ect.
all I learned is at that level I was not maxing my tc78 turbo.
I will be turning up to about 14 to 15# this fall and im running a progressive meth system so I might try a little more timing as well. shooting for 10 flat or so.
maybe a higher strung setup with more cam might have a bigger issue with the smaller turbo but my lq4 with a 206/212 duration cam does not seem to care.
try the dump first. what about the valve springs? at 6# your not really in the sweet spot of that turbo. mine was a 78/68 .96 with a 3.5 downpipe and felt good under 5800.
Old Sep 14, 2015 | 07:19 PM
Superman09's Avatar
LS1Tech Sponsor
No problem, I have exactly what you need that will flow where you need it and not take up more compressor cover space. If you change your mind let me know, our pricing is right too
__________________
69-chvl's Avatar
93 no meth
11* timing
5500 shift point.
Good info thanks Mike.
Old Sep 14, 2015 | 09:10 PM
93 no meth
11* timing
5500 shift point.
Hmm. My valve springs are doubles, not sure of the manufacturer. They were on the heads when I got them and they're patriot heads. The cam is a 230/230 but I don't think that should be a problem. I'll try the cutout first, if that brings up the rpm's a little bit then I think it'll be fine. Would more boost make the problem worse without the cutout cause I have a 10 lb. spring hanging on the wall for it but I need more fuel pump first.
Old Sep 14, 2015 | 09:13 PM
I may Superman and I know your prices are good, I just checked out a Turbonetics 7675 on your website and if I can get $1,000 or $900 for the TC78 I'll be giving you a ring. ; ) Is that what you'd suggest?
Old Sep 14, 2015 | 09:56 PM
Rawr256's Avatar
I would be curious how the tune looks if it's falling off that hard like you say. What is the AFR doing up at that rev? Could be a part of the fuel being too much or not enough timing. At a point there is the matter of determining motor life vs performance.
You could be running into some back pressure issues or it could even be that you are use to the power. Running my car at the wastegate pressure with the eboost 2 it doesn't have the same umph as when I turn it up to 9 pounds or even 12. Then if I open the cutout things get really nasty.
I did think something was wrong with my G8 after driving the TA for a while, then wife drove the TA for a bit then the G8 and thought something was wrong, and that's how I ended up with a LSA blower on in a weekend.
Old Sep 15, 2015 | 10:13 AM
Well and now that you say that Rawr I'm not sure the engine would live much longer with a bigger turbo. It's probably pretty close to 500 rwhp and it keeps me shifting at 5,500 rpm so this might be the best compromise between performance and longevity. I think I'll reach out to my tuner again and plan on installing a cutout, if your got nasty with it open I'd be hard pressed to believe it wouldn't be beneficial with my setup.
