Lq4 lasted 3 days
Old Oct 17, 2015 | 06:55 PM
Ws6Dnero's Avatar
Default Lq4 lasted 3 days
I was finishing up my d1sc procharger build on my car and my lq4 has already let go while doing some datalogging. Not even any wide open throttle pulls. I crunk it up today and it has a lot of blow-by at idle. Oil pressure also fluctuates from 40ish to low 30's. Hooked it up to HP Tuners to verify correct pressure but it is not reading at all. It only says -15psi and doesnt move up or down. Like its not reading at all. Pull the plugs on the driver side and the number 7 plug was coated in oil and black. All the other plugs look fine. Worst case scenario, i'll be needing to buy or rebuild the short block. So who is the recommended go to shop for a good short block? I'm thinking of just buying a good 370ci short block to get it back going.
Old Oct 17, 2015 | 07:59 PM
OverblownZ/28's Avatar
I have a rotating assembly
Old Oct 17, 2015 | 08:01 PM
Mappinsj's Avatar
You have a good idea. Buy a good short block
Old Oct 17, 2015 | 08:20 PM
JRENIGAR's Avatar
Thompson Motorsports is who Id go with. Kyle was a big help when I was assembling my setup.
Old Oct 17, 2015 | 10:35 PM
Ws6Dnero's Avatar
I sent kyle a PM earlier
Old Oct 18, 2015 | 06:27 AM
69-chvl's Avatar
Did you hear something let go on a pull? I'd check the oil, cut open the filter. Possible you just need an oil pump or the pick-up o-ring isnt sealing
Old Oct 18, 2015 | 08:18 AM
3 window's Avatar
I agree, check out the engine you have first before buyin another one. Might be something small.
Old Oct 18, 2015 | 08:38 AM
oscs's Avatar
Lmk what you want for the short block.
Old Oct 18, 2015 | 11:09 AM
coltboostin's Avatar
Broken ring land.
have any idea what your timing/ARF was at? You dont have to be full song to break somthing if your tune is way out of whack.
Old Oct 18, 2015 | 11:24 AM
RixTrix's Avatar
A complete diagnosis is in order or you may shortly need a second shortblock to replace the second ruined shortblock if the cause is not addressed.
Unless you can prove it was an ignition problem I would flow test the injectors and have a very knowledgeable person look over your tune.
Old Oct 18, 2015 | 12:50 PM
Ws6Dnero's Avatar
Injectors are new from FIC. Baseline tuning was done by Pat G. all the fuel components are new. Oil pressure is over 40 on the car gauge, but dropped after it warmed up. Dropped to like 30. Hp Tuners will not read the oil pressure though for some odd reason. Now i have so much blow-by coming from the dipstick, valve cover, and valley cover. I'm going to remove the driver head today, if the piston is damaged, i'll be ordering a new short block from thompson. I bought this lq4 as a long block from a salvage yard years ago. First set up it had 243's and cam. Now i just added small bore ls3 heads, and d1sc procharger. Would rebuild this motor myself but after 2 years of not driving it and having the pleasure of feeling "boost" for the first time for a few days, I rather avoid the downtime lol. I actually made ONE WOT pull for about 4 seconds. 12 degrees of timing and slightly rich for now.
Old Oct 18, 2015 | 01:19 PM
ddnspider's Avatar
Fbody PCM doesn't monitor oil pressure. Pressure sender is wired to the gauge cluster.
Old Oct 18, 2015 | 07:26 PM
dburt86's Avatar
Dont feel to bad, alot of us have been down that road.
In my last car, i broke a ringland, swapped in another stock block and broke a ring land again with in a week.
Old Oct 18, 2015 | 08:06 PM
Ws6Dnero's Avatar
Well I just removed the head. The head isnt beat up, few small barely noticeable spots. But yes the ringland is broken at #7.
Size:  255.2 KB Name:  047A1BA4-BFEB-44FE-BC93-E85B10E6E84D_zpsqn4ufxvx.jpg
Old Oct 18, 2015 | 08:29 PM
MY_2K_Z's Avatar
How does the cylinder wall look?
Old Oct 18, 2015 | 11:49 PM
Ws6Dnero's Avatar
not sure. couldnt get a good view. i just held my phone over the cylinder to get this pic. when i lower the car back down, ill take a look. Debating on if i should take the time pulling this motor and building or just buying a short block already built from TMS. after 2 years of the car sitting and building it, i dont think i have the patience to build a motor. I bought this lq4 from a salvage yard years ago. When i removed the heads and pan it had .10 over pistons and fresh cross hatching so it was rebuilt at some point and time.
Old Oct 19, 2015 | 12:47 AM
oscs's Avatar
Sell it to me for cheap and buy a real motor..
Seriously though..
Old Oct 19, 2015 | 02:04 PM
Ws6Dnero's Avatar
Seriously though..
You're welcome to make an offer......
Old Oct 20, 2015 | 02:31 PM
thompson's Avatar
We look forward to the opportunity to work with you. As always keep us in the loop and let us know if we can help with anything at all.
Thank you,
Kyle
972-853-2450
Old Oct 20, 2015 | 08:14 PM
Ws6Dnero's Avatar
Thank you,
Kyle
972-853-2450
Well I paid for the short block monday, thanks again Kyle.
