What camshaft for supercharged LS2
Sorry for my English, and thank You for help !
To save on a lot of supporting mods, I would probably use the ls9 cam/springs. Should be cheap and easy to find, as well. Plus, it's a factory cam, so it has nice, mild lobes... easy on the valvetrain.
When you say 2 x 2.5 exhaust, does this mean you have true dual exhaust with 2.5" pipes? The true dual exhaust is good, arguably a requirement with a positive displacement blower. But you are going to want to increase to 3" pipes, or larger, if it's at all possible. Optimally, you will want 2" primary headers with good collectors (race type with velocity spikes) leading to true dual 3.5" exhaust, with a functional scavenge pipe (X-pipe or H-pipe). I understand that the physical space for such an exhaust system may not be available in your application, but you need as free flowing exhaust as you can possibly get with a positive displacement blower.
Have you ever seen a Cam Dr. or Cam Pro sheet on the LS9 lobe??
What are You guys thinking about some "tuning" camshafts from eBay e.g. Lunati Voodo, BTR Brian Tooley Racing, Comp Cam, many of them are on eBay... ?
Yes, I have double 2,5" exhaust with X-pipe and two magna flow exhaust in the end... What You think, it is too tight ?
My exhaust:
Last question, my magna charger give 0.3 bar pressure. It is ok ? Do You know what is the LS2 resistance ?
Your supercharger is 0.3bar, or 5psi, so I assume it's the non-intercooled model, is this correct?
The resistance of the ls2...? I don't know what those words mean. The static compression ratio is 10.9:1 if that's what you mean. If you're asking about the structural integrity of the stock rotating assembly, then don't you worry... It's plenty strong, like can routinely handle 700rwhp, strong.
If you want a tuner cam, call one of the vendors on this site. Like if you want a Brian Tooley cam, call Brian Tooley, himself. Don't buy your cam off of eBay.
And, yes, I think your exhaust is too small of a diameter for a supercharged six liter. The true duals with an X-pipe is the correct layout or style, but I would want 3" pipes... 3.5" if it would fit. Positive displacement blowers love a free flowing exhaust.
Either way I can't see your present exhaust being an issue. I know you didn't state it but 5 lbs boost was thrown out there .... You will be at 7 lbs at least with stock pulley on the smallest blower mentioned. Again your 2.5" is fine. ( what I'm saying is I wouldnt spend an extra nickel on upgrading the exhaust until you start pushing big numbers... You won't).
lThats not an insult. You will make respectable power & a perfect setup for drifting. Crazy TQ instantly will get you sideways quick. Duals with an xpipe is perfect for your power level.
Stock short block .. 600 hp is about it for safety. If your running one of the blowers above you won't exceed that rwhp either way.
Re: Cam. If you are not willing to to have a custom grind I might suggest the Brian Tooley stage 3 blower cam. He has developed some nice off the shelf cams for PD blowers by utilizing a higher LSA with + advance. It was developed for LS3 but will work well with the LS2. Specs are somewhere in the 230/242 range on a 120 +5. The lift isn't too big & the advance makes a big difference on the performance. Drives great, chops like a big boy & makes the most of your small blower with next to zero overlap.
I've been through the mill with my previous motor ( in sig). PM me for any advice that I may lend assistance with. It's a great power plant but it has it's challenges.
Maximizing cylinder filling and limiting charge loss becomes that much more important when it comes to power output with these smaller blowers. Such as the MP112, MP122.
The 2300 doesn't have as big of an issue as the smaller blowers, but still doesn't like a lot of overlap.
As asked above, which blower are you running?
Has the car been tuned for the blower?
The dyno shop should have been able to tune it properly for you while you were there. I'm thinking it's your tune that is off.
Guy who was install this engine in my e46, has tuned this for the blower, but the power has decrease
Yes, these are the photos of my engine in my e46, do You know which model is this charger ?
I'm no expert on tuning, by any means, but it seems like your computer is actually keeping it from making power, probably in an effort to not explode. Check your boost readings, timing, and fuel ratios. Also see if it logged any knock/detonation during the dyno run. All this information should be available from your tuner.
There is no reason why it should lose power after the addition of this blower.
Do you have the print out of the dyno run. It has to show significant gains in the lower RPM range both TQ & HP. TQ especially. What I'm interested to see is if the IATs are so horrible that its stripping your peak numbers at the high end of the run. The old maggies are known for their extreme Intake Air Temps.
It would surprise me that the blower couldn't muster up enough pressure to let itself be known. Look for the gains across the lower RPM range. If they are non existent ( then as DavidBoren suggested) the tune is far out of spec.
Maybe timing is stripped to the bone ?
We can mitigate the high IATs with Meth/Water injection if that is the cause of the deflated peak numbers. First look at the dyno sheet and make note of the level of Boost, IATs & timing. Compare it to the NA version dyno sheet as well. You should see a considerable gain in TQ at low RPM. A line that shoots straight up and levels off close to 400 ft lbs by 3K RPM. If HP never catches up & TQ decreases ... take a look at the IATs & timing of the drop off. I'm no tuning expert but its a start.
Don't forget, if the IATs are so high that they are pulling timing you may be eliminating the benefit of the blower & not even covering the HP needed to spin that blower. This would be the worse case I've ever heard of ... but not impossible.
Exactly what David said " "
The injectors are original from the Magnuson set. I don't really know which exactly they are...
The iat are maximum 45-50*C... and I have in the cabin water temperature gauge, and it never exceeds 40*C... thats why I'm not looking for the problem here. I thinking about to low boost pressure ( 0.3 bar ).
Here are my dyne tests, yellow, from last Year, and blue, two weeks ago, after charger installation. What You think?
