Boost and Nitrous wet or dry?
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
You always need less timing and extra fuel when adding nitrous. If using a "dry" shot the ecu needs to add fuel. U want the n20 shot as close to the cc as possible for it to be most effective.
I was very new to boosting at the time and looking back I would have used a wet kit and spray 8" before the tb. I was scared of hurting the motor back then and sparyed the d1sc inlet to some what weaken the hit lol. But at the same time spraying the inlet with 75hp jet was enough to get on the converter flash and making boost a lot quicker.
circle d has these budget converters and they would be better than that stock one.
http://www.circledspecialties.com/p-...converter.aspx
If your tune is rich and your timing curve isn't on the ragged edge, a small shot might not cause problems. That doesn't make it "right". The proper way to do it is to add fuel and drop timing.
Nitrous will NEVER cool the combustion chamber. You are adding oxygen, which will make the cc much hotter.
