"Low down & dirty" 5.3-78/75-TH400 Skylark 11.25@122
Old 02-12-2016 | 07:40 AM
  #121
a4ls2goat's Avatar
What size return are you using?
Good stuff on getting it started!
Old 02-12-2016 | 10:47 AM
  #122
dirtylark71's Avatar
Yeah no vac line on the turbo. I'll post a picture of how retarted my return line is. I originally planned to have the turbo in a different location so I put the drain in according to that, but plans changed haha. Good luck on your start up forcd!
It's a 3/8 return, I used parker push-lok jiffy tite hose from a local supplier. it works great and is real easy. If you use it, just put some soap or some **** on it to help lube it up.. lube is a good thing hahaha. When are you going to fire up that beast RX?
It's funny I get it started and then I am like.. **** I have a lot to do still, well I'll get after it and keep pluggin away
Old 02-12-2016 | 10:53 AM
  #123
forcd ind's Avatar
Well, mine went pretty good, except the front crank seal is leaking, it didn't last year, but an easy fix
I was prob more worried about the trans, since I am not exactly a trans guru, but have built enough to have an idea if its going together right, lol
It seems to have all the gears, so prob ok
Now I have have to wait for good weather, lol
Old 02-12-2016 | 10:55 AM
  #124
andddd then burnouts! Your car is an early A-body right? 64-67?
Old 02-12-2016 | 12:14 PM
  #125
forcd ind's Avatar
65 sedan
Old 02-20-2016 | 10:19 PM
  #126
Old 02-21-2016 | 12:57 PM
  #127
Project GatTagO's Avatar
10 Year Member20 Year Member
Next time turn phone 90 degrees...LOL
Andrew
Old 02-21-2016 | 03:31 PM
  #128
lol sweet I am on it! thanks for the heads up
Old 02-21-2016 | 04:50 PM
  #129
a4ls2goat's Avatar
Hoping to have it fired up today. I tried it yesterday but it didnt wana start. Idk if the ground is not good enough. I gota check a couple of things.
Old 02-21-2016 | 06:36 PM
  #130
what kinda issues? I got a decent amount done today I will post some pics later. Going back through and finishing up all the wiring this week and should be rolling
Old 03-10-2016 | 08:36 PM
  #131
Old 03-11-2016 | 05:56 AM
  #132
a4ls2goat's Avatar
3/8 as a return is pretty small. If its smoking that could be your issue. Go to a 5/8 return
Old 03-11-2016 | 09:44 AM
  #133
5/8 return. I thought you meant fuel return haha
Old 03-11-2016 | 09:50 AM
  #134
a4ls2goat's Avatar
O ok.lol
Old 03-11-2016 | 11:53 PM
  #135
76/68 from vs racing. Viren is a real awesome guy to deal with. I could tell he was busy but he made sure to e-mail me back quickly and he also talked to me on the phone with great customer service. Will definitely go back to him. I will pull the gt45 off tomorrow and take a peek at it and throw this guy on. Hopefully be rolling into some boost tomorrow
Old 04-07-2016 | 02:44 PM
  #136
  #137
So if you watch the video I re-capped the long gap of not updating. Sorry about that haha but overall car is running great here are some pictures from the past few weeks
Old 04-07-2016 | 03:07 PM
  #138
This is my good friend James "The dude". He has helped me a bunch with sourcing parts (the motor, tranny, and he built the rear end). We found that th400 for 100 bucks at a swap meet.
This is Mike Finnegan of Roadkill putting a Roadkill sticker on my car. He said "You know it is going to break now right?". He also said "please don't ever paint this car".
This is how the car is sitting after swapping in some Moroso Trick front spring I had laying around that were cut a bit. On the *** end James had to idea to cut the spring even though its a tight coil at the top and just let the Upper part of the spring sit in the pocket. Hard to explain but it worked out great!
These are the wheels and tires from my GTO but they look sooo good on this car.. uh oh
Old 04-07-2016 | 03:11 PM
  #139
Just incase you don't watch my horrible video the car has ran a best of 11.66@116 with a 1.72 60' so far. Blowing through converter bad
Old 04-13-2016 | 11:46 PM
  #140
Idk why I cut it off like a retard haha but it was on like 10psi just ******* around in mexico..
Thinking about swapping in a different converter maybe just a stocker see if it is better just for a comparison. Haven't decided yet. Front cover is pushing oil like a boss, so I am pretty sure I have some crankcase pressure issues to deal with... orrr just ignore it.. like I have been...
Quick Reply: "Low down & dirty" 5.3-78/75-TH400 Skylark 11.25@122
