Injector Question
Old Jan 22, 2016 | 12:05 PM
t-town's Avatar
Default Injector Question
My latest project is a Fox Mustang with a 6.0 and 4L80 tranz. I have a 78/75 turbo with a Tick performance stage 1 turbo cam. I am using twin Walbro 450 LPH in tank pumps. I am looking at a set of Deka 80lb injectors to buy for this. This is going to be ran on E85. My questions are. 1, Will this be enough injector. 2, is this a good brand of injector for the money and how I am using it? Are there any other suggestions? Thank you for ur time.
Old Jan 22, 2016 | 12:44 PM
JoeNova's Avatar
Restricted User
Are the injectors enough for what?
Are they enough for 600whp? Yes. Are they enough for 800whp on E85? Yes, with enough fuel pressure.
You never said what you plan on making power wise.
Are they a good injector for the money? Yes, they're probably the best bang-for-the-buck injector out there.
Old Jan 22, 2016 | 12:58 PM
t-town's Avatar
The goal is to make between 700-750 hp at the wheel. This is primarily being used as a street car. Thanks again.
Old Jan 25, 2016 | 06:15 PM
rpturbo's Avatar
Curious, have you mounted your pumps yet? If so, do you have any pics of how you mounted them? I am building the same setup basically in my S10.
Old Jan 25, 2016 | 06:55 PM
Area 51 Racing's Avatar
Like JoeNova said, Deka 80s and Jack up the fuel pressure for your goals.... or use all of your tax return on some big boy FICs
Old Jan 25, 2016 | 08:11 PM
lmt0705's Avatar
if you have not bought them yet, go bigger. you will want more power sooner than later and youll max those quick on e85
Old Jan 26, 2016 | 01:47 PM
t-town's Avatar
ok, thanks
Old Jan 27, 2016 | 11:23 AM
svslow's Avatar
Which tank are you using that will fit two 450's?
Old Jan 27, 2016 | 05:31 PM
sbdgbody's Avatar
I like to know to one 450 just barely squeezes in lol
Old Jan 27, 2016 | 09:06 PM
lmt0705's Avatar
I just did mine, had to notch the tank a little too get them in. I used an exacto knife inside of where the o ring goes
Old Jan 28, 2016 | 02:06 PM
t-town's Avatar
I am using the on 3 hat and 04 cobra tank.
