water meth
Old Jan 27, 2016 | 09:32 PM
Seeker1056's Avatar
Default water meth
is there a calculation or rule of thumb for how much water meth that needs to be injected per lb of boost or some other measurement
I am building two twin turbo projects and plan to hit 15lbs or so boost on pump fuel
I have read that a 50/50 mix is best all around but can not find a baseline amount to start
Old Jan 28, 2016 | 05:50 AM
boostedxs's Avatar
I'm doing my first ls turbo build right now. However I've used meth with turbo builds on other vehicles and alwaya ran a 50/50 mix with good results. I would start there, just watch your air intake Temps on your first runs. The bigger question for me was always how big of nozzles should I run. At the end of the day everyone's setup is slightly different and will yield slightly diff Results
Old Jan 28, 2016 | 05:53 AM
Seeker1056's Avatar
the bigger question is my question - how much to inject - so yes - how big a nozzle or nozzles
Old Jan 28, 2016 | 05:57 AM
stevieturbo's Avatar
No calcs, no rules, there are way too many variables.
Some calcs that may exist...could easily be halved or doubled which makes the original calc pretty pointless in the first place lol
And 50/50 may or may not be best...again too many variables.
And again depending on build etc.... meth certainly isnt essential for only 15psi
Old Jan 28, 2016 | 06:33 AM
Seeker1056's Avatar
seriously - so everyone in this turbo game just bolts something on for water/meth and hopes for the best - very doubtful
h0w many on this forum are running it and what do you run for a nozzle(s)
what is your favorite brand?
Old Jan 28, 2016 | 06:57 AM
No, but they at least have some useful information to hand to make a guess.
At the end of the day, they're all just dumping in whatever they dump in, and then tuning around it. It could be a small amout or large...again there are many variables.
Old Jan 28, 2016 | 07:25 AM
Seeker1056's Avatar
from Devils Own - Most cars should aim for 15% of their total fuel flow. Some more extreme setups run as much as 25% of their total fuel flow.
now the question to research is what size nozzle to use - or should one use multiple nozzles more like a nitrous manifold setup
Old Jan 28, 2016 | 07:34 AM
JoeNova's Avatar
Restricted User
Pretty much. On any turbo V8 car, I just go straight for the biggest nozzle supplied with the kit. It's usually around 10 got.
Old Jan 28, 2016 | 11:34 AM
Forcefed86's Avatar
Devils own site has a nozzle size calculator on the home page. It's a good place to start if you are running 50/50 and a basic kit with basic goals. Planning on an intercooler?
Old Jan 28, 2016 | 01:44 PM
Seeker1056's Avatar
found it
http://www.customperformancesolution...injectioncalc/
Old Jan 29, 2016 | 08:40 AM
Monte4ever's Avatar
I just add enough to knock my AFR down .5 then pull fuel to get it back to where it was originally.
Old Feb 7, 2016 | 02:49 PM
KY Nova's Avatar
I've got a #14 on the inlet of the blower and 2 #10 in the charge pipe and will probable be stepping those up. 50/50
Old Feb 7, 2016 | 07:48 PM
dburt86's Avatar
Thats how ive always done it to
Just keep in mind that meth is a fuel, so the more meth you run, the more you need to pay attention to distribution.
Not that its not important with 50/50, but it gets a little more serious when your depending on it for fueling.
Old Feb 8, 2016 | 12:34 AM
Blown06's Avatar
8 Second Truck Club
I never mixed water. Always ran 100% meth cause I needed a crutch for my inadequate fuel system. Just another example of how different people use it. I had a single m15 nozzle and whatever pump comes in the alky control kit turned all the way up.
