ls9 style gasket for small bore
I've built out a 3.82 bore (.040 over) 4.8 engine and I'm a bit uncomfortable running a bigger bore ls9 gasket.
I know lots of folks do without issue but it seems to me it would leave quite a bit of "crevice gap" due to the larger bore
would o ringing help fill that empty space? or is there a similar MLS composition gasket that would fit this bore size better?
thanks!
Tried the FelPro that fit the bore. They failed at 19 psi.
LS1 gaskets failed at 15 psi
So put the ls9 on, 18 psi. All good.
Disassembled for upgrade, the ls9's showed zero signs of distress.
Ron
did you notice that the space between the gasket fire ring and the edge of the bore had "filled up" with carbon deposits?
I'll be sticking with the LS9 too many success storied.
thanks for all the feedback.
I resisted using them because I have an alum block. But in the end, "they" were all right, it's the gasket to use. :-)
Ron
