Power Valve Delete for Drag Race
I know most of you guys run EFI, but just for ***** and giggles, I'm blowing old school with a carb. In the N/A drag racing world, cars will just delete the power valve and square up all four corners, then jet accordingly. Before I drill a hole through my carb body for a BRPV, has anyone ever done this on a blow through? I'm running about 22psi and the QFT power valve does not get the job done. I could put a crutch setup on it, but part throttle is pretty much needless. My motor runs two speeds, idle and WOT. On a drag car, no power valve is pretty much standard. I'm getting the bung for my wideband welded on today so next time out I'll have numbers to tune with. Running E85 in a jet boat.
Soooo, has anyone ever done this? Blow through turbo with no power valve.
Pretty much on the blow thrus I always ran a boost ref PV-the problems with running with out one was keeping the plugs clean at idle-not sure how that works out with E85
Even back in my old super stock days I always ran PV's while guys were plugging them-some would drill holes in the pri throttle plates to trick the engine into thinking it was lean at idle so they could try and keep the plugs clean on the starting line
Try it and see, some of the guys ran PV's front and rear
I know when Kevin (CSU carbs) would build me a carb with a boost ref PV the jetting wasn't huge, but it would flow some serious fuel
Funny, when I switched to FI, a guy was helping me, and I was trying to relate certain issues to how a carb was tuned, the guy says I have never worked on a carb, so I cant relate, lol-gotta love the new world order, lol
A lot of good carb/boost info here.
http://www.theturboforums.com/forums...Tech-Questions
Pretty common if you don’t need lean cruise to block the PV with Alcohol based fuels. They don’t foul the plugs near as bad either so running fat at idle isn’t as much of a problem.
You can also run your PV externally if you don’t want to drill holes in your carb. A meth injection jet on top of the carb hat and WOT solenoid (similar to a nitrous kit) will do the same thing as a BRPV. It’s also easier to tune IMO. You can “T” in right off your regulator as well so it will be boost referenced.
well my understanding of PV is wrong then. I thought they opened only under vacuum not boost??
so it sounds like the "transition" of vacuum to boost causes a lean out condition.
I didn't think the PV would cover that ???
