Twin Turbo LS Boat Engine
Old Feb 22, 2016 | 04:35 AM
stevieturbo's Avatar
Aus, but I believe Dale has tuned a few boats etc
http://www.castlehillperformance.com.au/page.php?id=9
Old Feb 24, 2016 | 02:51 AM
Huffa's Avatar
So I purchased a 5.3 LS cast block engine, done about 85000 miles supposedly. Now just need to get some bits. Are masterpower turbos any good? Easily available here. Would these be a good size for my requirements?
http://www.trademe.co.nz/Browse/List...?id=1036225139
Old Feb 24, 2016 | 04:25 AM
S2KIWI's Avatar
Holset has local support.. can put you in touch with someone if you'd like.
Old Feb 24, 2016 | 06:49 AM
Just buy Borg Warner. They're cheap, readily available and very reliable.
Old Feb 24, 2016 | 12:07 PM
Huffa's Avatar
Yea they look good , just trying to avoid having to import from US, the exchange rate is crap at the mo, basically I have to double that price to get landed here with exchange, taxes,shipping
Old Feb 24, 2016 | 12:08 PM
Huffa's Avatar
Yea that could be worth a look if they are local,ta
Old Feb 24, 2016 | 01:57 PM
So do I, but it's still usually cheaper than buying locally ! And at least there is supply.
I can get **** all here !
Old Feb 24, 2016 | 07:57 PM
LSswap's Avatar
Whatever turbo you choose, make sure it's got water cooled bearings. Some of the ones posted above don't. You'll need cooling more turbo cooling than most.
Definitely support the weight of the turbo(s). With all the bouncing around, your manifold will not.
Also definitely include an oil cooler in your build.
Go for a higher AR on the exhaust housing since you're RPM range will have no problem making boost at constant rpm. This will help keep your exhaust pressure lower.
Go for the largest water intercooler you can manage. High charge temp will cause detonation and most intercoolers are designed for short bursts and get heat soaked.
You're probably going to need to go higher than 10-12 lbs of boost to reach your target.
Consider a colder rated spark plug to dissipate heat better.
If you have the option for Ethanol, go for it. it will run cooler.
Not sure about BOV setup. I would guess in a race boat, you're constantly on and off the throttle instead of constant RPM. You may have a hard time maintaining boost. Maybe consider doubling up on your BOVs. Consider an engine management system that can give you anti-lag when you back off the throttle.
I prefer single turbo setups. Fewer parts, less points of failure, no chance for harmonics and turbo surging.
My 2 cents. Best of luck. Be careful, lost a car buddy in a race boat.
Old Feb 25, 2016 | 02:30 AM
Huffa's Avatar
Thanks for that. So could I run twin intercoolers, one for each turbo, these be any good?
http://www.trademe.co.nz/Browse/List...?id=1039727403
And these turbos. Would they handle my 3 or 4 races a year or just rubbish and not worth the risk?
http://www.trademe.co.nz/Browse/List...?id=1039609290
Old Feb 25, 2016 | 04:26 AM
They're chines knock off turbos...they may last, they may not. They may perform, they may not.
Also that cooler looks terribly small. There are few downsides to oversizing a cooler.
Check out oscs's Datsun thread, he recently bought a decent sized core very cheap
https://ls1tech.com/forums/forced-in...l#post19161705
Old Feb 28, 2016 | 01:21 PM
Huffa's Avatar
So for headers to suit the boat am I best to use the truck headers or buy a set of turbo headers from ebay or somewhere?
Old Feb 28, 2016 | 03:50 PM
  #32
Whatever works easiest for you really.
factory stuff is easy because they're cheap and robust. So if they work for you, they'll make a lot of sense over more expensive stuff. They just dont always look as nice
Old Mar 4, 2016 | 04:23 AM
  #33
Huffa's Avatar
So have been quoted some turbos locally, would these be the right size for my application? Some people experienced with setting up twin turbos in race boats have said to run quite large turbos with 50mm waste gates, not be concerned about low down boost or spooling up as we will be sitting at 5000-6000rpm most of the time and easy to get going. Would these be considered large or not? Another guy is quoting me borg warners, I havnt got the specs yet but twice the price-thoughts please
http://www.trademe.co.nz/motors/car-...1044519412.htm
Old Mar 4, 2016 | 09:20 AM
  #34
A pair of them might do 700 at a push, but IMO they're on the small side for a 6.0
And that really isnt a cheap price...for what appears to be a really cheap unproven turbo
A quick google brings up this as a NZ supplier of BW and other units ?
http://www.turbochargersnz.com/perfo...a/#Performance Turbos and Parts
Old Mar 4, 2016 | 11:48 AM
  #35
Huffa's Avatar
Thanks for that, that was what I wanted to know, well looks like I will have to pay the money and go with the borgwarners warners @ $1650+gst each. Turbocare in Christchurch have set up 3 or 4 race boats, vk56 twin turbo and 2jz twin turbo are some of them and they go real good and have done so for a good while now, apparently they know what they are talking about which is what I need as I know f all
Old Mar 12, 2016 | 07:02 PM
  #36
Tknz's Avatar
Hi huffa,
Are you in Queenstown for the race this weekend? We have built an boost ls engine to stay in A class, there's some quick Boys in U
Old Mar 12, 2016 | 10:18 PM
  #37
Huffa's Avatar
Hi, no not down for that race weekend. Yea I realise there is fast boats in U class, but just out to have fun really and try to finish. What have you done for headers in your boat?
Old Mar 13, 2016 | 12:30 AM
  #38
Tknz's Avatar
We have gone centrifugal blower, Ken at sss in chch could help with headers, where are you in nz, it is great fun, very addictive.
Have you already got the motor
Old Mar 13, 2016 | 07:49 PM
  #39
rpm-inc's Avatar
Have you seen my thread on performance boats? Here is a pic of vbanded c6 vette manifolds.
Old Mar 14, 2016 | 01:18 AM
  #40
Huffa's Avatar
No I haven't seen that thread, cant find it, I am useless on the computer,could you paste a link, looks good, what turbos? What do you guys do for an intercooler? I have been told I need a 3 stage cooler, not cheap. I have the motor at engine builders, haven't seen it for myself yet. Got a new cam/springs and pushrods coming, gone with the borg warner turbos, shoud have them later in the week.
