Twin Turbo LS Boat Engine
http://www.ebay.com/itm/Y32-Fuel-Rai...KIILYqlE1o02Bg
So am I best to still use LS1 injectors and space the rails or would these be good and go in without spacers?
http://www.ebay.com/itm/331711195701?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
8 96lb Fuel Injectors for GMC Cadillac Chevrolet 4 8L 5 3L 6 0L 01 07 1000cc | eBay
Let me know if those rails fit as described.
http://www.trademe.co.nz/motors/car-...1065127831.htm
Was starting to thing I should stick with LS1 injectors in case I change intake one day then the injectors will swap over
There's really no reason to change the manifold unless it's an aesthetics or packaging thing. As long as the intercooler efficiency is greater than the turbo's compressor efficiency(which it will be), adding a little boost to cover a slight manifold deficiency will be better than a wash in comparison. Mathematically anyway. Not aware of a test to prove the theory as of yet.
Bottom line, the truck manifold will be fine.
Only variances are some newer engines and LSA and above have more bolts to retain the flex/flywheel, all older engines just used a 6 bolt crank.
LS w/ Flexplate and 1310
LS w/ flywheel and 1310
LS w/ Flexplate and 1350
LS w/ Flywheel and 1350
I used the flex/1350 for my 5.3
The bolts are nearly impossible to find, make sure the adapter comes with them and/or order them at the same time.
If you've got a source for them, you'd be doing the LS boat guys a favor. $45 for the 6 of those suckers. Yikes!
