Cruising AFR
Old Feb 29, 2016 | 09:20 AM
Shownomercy's Avatar
Man-Crush Warning
Default Cruising AFR
What do you guys shoot for?
Old Feb 29, 2016 | 09:46 AM
JoeNova's Avatar
Restricted User
I cruise at 15:1 in overdrive. Adjusted timing until it behaved itself and went with it.
Old Feb 29, 2016 | 09:54 AM
Man-Crush Warning
Yea mine is doing 15-16 area light cruising, and was just curious what others did.
Old Feb 29, 2016 | 11:03 AM
RonSSNova's Avatar
I'm in closed loop
Ron
Old Feb 29, 2016 | 11:50 AM
kingtal0n's Avatar
If I can get it to be consistent, open loop 15.2:1 in most cruise areas. However, I have interlaced the fuel map so some cruise spots are 14.8:1 and some are 15:1, that way the engine does not always sit at 15.2:1 for extended periods. There is not much fuel to be saved by running it slightly leaner, some for sure but not much.
The real economy is in the timing. Pull out timing until EGT goes up noticably to establish a lower limit, then gradually add timing until your datalogs are showing a severe diminishing returns (less and less EGT drop for additional timing added). Many different engines I have tuned, all seem to fall in the 33*-40* range for optimal cruise timing. For the most part. Ancient chevys like 1985 year 2-piece block iron heads low compression, emission heads with carbs on 93 would take 44* (and 36 total WOT) but newer engines need much less.
Old Feb 29, 2016 | 12:28 PM
stoverz28's Avatar
Y'all are talking about 5-10lbs vacuum light crusing right?
Old Feb 29, 2016 | 12:30 PM
JoeNova's Avatar
Restricted User
Well I hope he doesn't cruise at wide open throttle.
Old Feb 29, 2016 | 12:46 PM
Man-Crush Warning
I couldn't afford the fuel to travel at WOT lol
OLSD tune, and usually about 18in of vac crusing at 65mph
Old Feb 29, 2016 | 01:21 PM
kingtal0n's Avatar
As much vacuum as you can squeeze. Adding the correct timing (do not add too much!) and watching EGT drop should give you some additional vacuum signal and a lower throttle position as the engine makes better use of it's fuel. You can also reduce vehicle weight, adjust tire pressure, alignment, lower brake drag, grease fittings/replace bearings, better balance rotating parts, make the vehicle more aerodynamic for higher speeds, use less friction tire compound, all of this should make the vehicle more fuel efficient and increase engine vacuum during cruise given the same displacement engine.
In the old days before widebands and fancy EFI engines, we would read plugs and adjust fuel/timing for better engine vacuum cruise.
Old Feb 29, 2016 | 11:21 PM
stoverz28's Avatar
Lol, well I kind of figured that.
Had to ask though since my **** seems to go crazy when seeing atmospheric pressure while cruising, mainly when going up hills at lower rpm.
Old Mar 1, 2016 | 06:45 AM
forcd ind's Avatar
I shot for anything in the 14's, but it can go all over the place due to stuff, I am happy if the engine is happy, lol
