procharger pulley size questions
need help guys, running a 416 with an F1c and want to hit the 1001 rwhp mark. what crank and blower pulley sizes would i need? been researching and found an impeller speed calc. the max impeller speed on an f1c is 74k. with an upper 4" pulley and a 8.5" lower, 6500 rpm shifts, the impeller speed is a 74.5k. any clue on what psi this will be?
416 10.1:1
stock ls3 heads
stock ls3 intake
1 7/8 header X pipe 3" true duals
238/248 115+4 cam
TIA
416 10.1:1
stock ls3 heads
stock ls3 intake
238/248 115+4 cam
TIA
If you max the speed and boost without slipping your belt you might be close to the 1k mark, i know its capable of 1200+ fwhp just not sure with stock heads & intake yet its possible just maybe depending on drivetrain power losses.... A2W may help with timing and inlet temps... What has your best results been so far?
416 is done
f1c - have
bracket- have
going A2A 4.5" intercooler core
e85 "flex fuel"
trying to get the pulleys next
LS1Tech Sponsor
416 10.1:1
stock ls3 heads
stock ls3 intake
238/248 115+4 cam
TIA
416 10.1:1
stock ls3 heads
stock ls3 intake
238/248 115+4 cam
TIA
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
I agree. Bob
__________________
