ATI GUYS NEED A FILTER? try this......
I don't know if it is big enough though...
Front of this beast
Will it fit????? I think there is plenty of room.....glad I relocated my air pump to behind the fuse box when I had a powerdyne on the car
Josh pull the inner fender well and pull the bumper cover DAMMIT, Yep it fits
Get assorted 90 deg bends from previous K&N set up reconfigure and BAM
All pieces are up and clamps tightened down, fits perfectly I can even fit my finger infront of the air filter(front is resting about 2 inches below the driver side marker light)
Definately need a shoe horn or extra set of hands but a filter this big fits fine. You can hear this big sucker sucking air from 5ft away
I even put the ATI cover back on so the filter stays protected from the water. Not bad for a 1.5 hours of work including a 3.4 pulley install....Enjoy,
J
And don't mind the half oiled filter pics, I ran out and had to go buy some more.
J
PM sent back too,
J
At first I thought I wasted 50 bucks......but then we took off the old assembly I had going and pulled and pried until it slipped in fine and made sure it had clearance around the front of it and on the sides, which it does quite nicely. It didn't even bow out the front bumper cover any
Feels faster but who knows until I get it to the dyno and track,
J
Its especially loud by the fog light....I thinking about removing the fog lights now
I might have to try again, and drop the cooler on that side to get it in there....I'm sure my little dinky filter is sucking up some power
When I had my baby Powerdyne I used a filter close to that size versus the stock PD setup and picked up 4-5mph with NO other changes.
HUGE difference
you guys will see even more
Bos, probably don't have to drop the cooler, just have another set of hands helping you. My buddy Josh pulled the inner fender liner toward the tire and pulled the bumper cover out towards him, this gave us enough space to slip the filter up and into the space. Fits like a glove.
J
I had to drop the intercooler and move some stuff to fit it in. If I had the AIR pump and cruise bracket in there it would never fit.
I couldnt get mine to fit like Mike's, no way it would fit through between the intercooler and pipe, thats why I just took the intercooler off to put it on.
Anyways, for the street testing, its about 90 degrees here now, with about 90% humidity.....
I took it for a blast up to 6K and saw 11psi.......
I was seeing 9psi all day long yesterday with the same weather.....now, if the rain holds off I plan on taking it out tonight when its cooler to see what it has in it.....
Now the ?........is there a need to redyno?
