MLS, Copper, etc
Old Apr 21, 2016 | 02:58 PM
stevieturbo's Avatar
Default MLS, Copper, etc
Again, it's just an article to have a nosey at. The thread doesnt need to start talking about axles or something similarly completely irrelevant.
http://www.enginelabs.com/engine-tec...ls-and-copper/
Old Apr 21, 2016 | 06:31 PM
gsteele's Avatar
The article quoted someone from Borowski Race Engines. Hey, that is not too far from AES Racing. I hear that they do some righteous work.
Old Apr 22, 2016 | 04:48 AM
MLS gaskets really work superbly...but one thing they do mention and many have experienced...is the blow torch effect.
I had always put that down to bad tuning, detonation etc etc..but the more it seems to happen, it does just seem to be that if you blow a MLS HG on an alloy platform, that aluminium stands a good chance of getting torched.
Whereas any soft metal gasket just seems to blow and absorb all the damage instead.
Old Apr 22, 2016 | 06:55 AM
boostedxs's Avatar
very informative article and straight to the point on alot of facts. comes right back to what most of us already know as far as the MLS gaskets are concerned. and they pretty much shot down the whole using of gasket sealer with mls. also the ability of a copper gasket to somewhat "recover" makes sense to me. I hadn't realized their using copper on top fuel either. nice find
Old Apr 22, 2016 | 01:17 PM
ablakez28's Avatar
Very good article thank you for sharing. I personally have had no head gasket failures using LS9 up to 26psi. I install them dry but on a few I reused them and coated them. They seem to not like the coating in the article but having boosted used ls9s with copper spray on them to 20+ i would say it still works.
What do you think about the statement that more layers is not necessarily better? In the LSX community with so many having good luck with the ls9 its hard not to have the thought that more is better.
I would love to see more information about the newish trend of the gaskets like the cometic mlx with the stopper layer integrated.
We are trying the MLX on my new 427 that will be seeing around 30-35psi from s476s here in a few weeks.
http://www.cometic.com/catalogs/autodomestic.pdf
http://www.cometic.com/automotive-gaskets.aspx
Old Apr 22, 2016 | 04:21 PM
That's only because people are misinterpreting the coincidence the LS9 has more layers and it works well, rather than it being the design of those layers that makes it work well
I've used MLS on other engines with as low as 3 layers, and as many as 7 layers....they all work superbly. Just the ones with more layers were much thicker as required to get correct piston to head clearance etc
Old Apr 23, 2016 | 12:29 PM
ablakez28's Avatar
That is what they are saying in the article. Felpro does not agree it seems?
http://www.hotrod.com/how-to/engine/...-head-gaskets/
Old Apr 23, 2016 | 01:20 PM
Yet strangely when I mentioned FelPro and their stopper design ( Which Cosworth use and I believe the LS9 also uses ), some members either here or YB, cant recall which but they said the FelPro's were *****.
Certainly at SEMA or PRI when they first came out a few years ago, they were spouting lots of blurb about them, I tried to buy a set from a couple of places but to no avail.
They just seemed to disappear after that though
but it comes down to same thing, it's the makeup of the layers more so than actual number. You could probably squeeze 10 layers in on a lot of gaskets...but they dont do that either.
