High Z injectors larger than Deka 80s
As we all know, these are the best bang for the buck, $/injector flow. What are some options when you go to a larger High Z injector without spending $1000? Also would only consider an injector that has injector data avalaible.
I see the IN900 injectors for ~$525, but that doesnt get you much further (10% more).
Wonder if injector data is available for these, or any of these other >80 lb/hr high Z injectors?
I am going to be running MS Gold, so I dont even know yet what is available as far as injector parameters in Tuner Studio. I tune alot of vehicles with HPTuners though on stock PCM's and there are quite a few tables that need to be changed when swapping to a different injector.
I found some solid injector data for these injectors (not everything needed for factory PCM and HPTuners) but it might get me by with MS.
But, I cannot find these injectors any cheaper than $100 a piece. I dont want to spend much mroe than $500 if I can help it. Wish there was something in the size range of 100-120 lb/hr @ 3 bar fuel pressure. I would prefer to run 3 bar base with boost reference so my pumps have a little more room...this would still be 4.5 bar FP under boost.
Whoops was in my watched list I didn't even look. Search by the PN others pop up for that price...
Bosch 0280158827
Here are some only have 6 available though...
http://www.ebay.com/itm/BOSCH-028015...RSrxML&vxp=mtr
Bosch 0280158827
Ran across a thread on LS1Tech that says to stay away from these injectors...that they are a "modified CNG 827 injector". Compressed Natural Gas (CNG) but dont know what an "827" injector is. Someone stated they are finicky with fuel temperature change.
Link to thread? Last 3 digits of the PN are 827...
Most of the big hi-z injectors are CNG injectors. They are nothing like the older ford CNG/LPG injectors that were such a pain to tune. Import guys have been using these and the 210lb bosch injectors for a while know and really like them. I've never used a set thou...
The 827 do have a fuel temp sensitivity, it's a fact.
Why do y think ID quit selling them?
I wouldn't give 10 dollars for a set
Friend had a set he finally got rid of, clear as day they flow less as fuel temp rose
Found it
http://www.ebay.com/itm/BOSCH-028015...-/172195669877
With shipping, it would be $552 a set, not too bad
I started the thread
"Help me understand injector prices"
Soon as you go over 80lb it seems, there goes the price ! It literally doubles, or more!
Why can't I buy an off the shelf 160lb on up Bosch injector for the same price as an 50,60,80 etc.?
Nobody "flow matched" it, not a "dynamically" flow matched a set, not a drilled, ground, re-labeled or what the **** ever! Just a new, in the box stock injector....
Believe me, i totally understand and appreciate the work, tooling, time, energy, expense that goes into IDs, FIClinic,FIConnection,deatschworks etc.
Ok, rant over, please proceed.
Ha. You u are better off spending little more for the "821" 2000s.
If you have fuel quality issues and want something not susceptible to corrosion issues like the 821 and 827 I would spend a little bit more yet for the Bosch ANSU stainless 1650s
