Holley Sniper intake review
Old Nov 30, 2016 | 12:38 PM
  #41
pozesd99''s Avatar
Do longer or shorter runners require a higher rpm range? I always get confused
Old Nov 30, 2016 | 04:44 PM
  #42
stevieturbo's Avatar
Short runners will usually see the engine perform better at high rpm's
Old Dec 4, 2016 | 02:54 AM
  #43
sschoeffler's Avatar
Installed and plumbed
Old Jan 25, 2017 | 11:17 AM
  #44
blownescalade62's Avatar
How is this intake working out for you?
Old Jan 26, 2017 | 02:21 PM
  #45
Have not been on the dyno yet but the car makes a **** load of power
Old Jan 26, 2017 | 07:40 PM
  #46
Thanks how much boost you running?
Old Jan 26, 2017 | 10:19 PM
  #47
gols1go's Avatar
Whats your intercooler setup?
Old Jan 29, 2017 | 08:41 PM
  #48
Just got it out today. Had the boost controller set at 18psi. Hit 18psi very fast. Car broke the tires loose at 120. I run 325/50/15 tires. Haven't had it dyno tuned but it's very fast and very responsive.
Old Jan 29, 2017 | 08:44 PM
  #49
I'm running twin air to water intercoolers. Have yet to fab the water box so as of right now, it's not intercooled. No idea what my IATs are. Car has been sitting for about 2 hours. Stainless headers are cool. Intake manifold is very warm but not hot. It will definitely pick up heat from the motor.
Old Jan 29, 2017 | 09:46 PM
  #50
MY_2K_Z's Avatar
So butt pucker followed by a huge smile. That's awesome man glad your finally enjoying all your hard work.
Old Jan 30, 2017 | 05:20 PM
  #51
98_LS1's Avatar
Are these the regular version intakes that are fitting under the stock cowl or the new short runner ones?
Old Jan 30, 2017 | 06:58 PM
  #52
Regular as far as I know.
Old Jan 31, 2017 | 02:10 AM
  #53
gols1go's Avatar
It is the short ones that fit under the cowl of the f-bodies and corvette's. The regular one is almost the same height as the Holly hi-ram.
Info on them on Symbol Performance website: http://symbolperformancellc.com/prod...ntake-manifold
Old Jan 31, 2017 | 12:30 PM
  #54
Well I bought the intake through tick performance and it came with the fuel rails. It says holley sniper on the intake. It cost less than the one on that website site but it looks pretty much the same. I'm very happy with my purchase. It looks damn good, makes a ton of power, seems well built. I'll tell you this, I would trust this intake over a plastic GM intake. So far I've ran 20lbs through it and all is good. Before I bought the intake I read lots of reviews and people saying the metal will distort and balloon. Well that's a bunch of Bullshit. Here is a picture of it today.
And here's a little video.
I recommend giving Eli over at Tick Performance a call. He gave me a great deal and he's a great guy to work with.
Old Jan 31, 2017 | 12:46 PM
  #55
It would be rather difficult to see any distortion taking place on a photo lol
And the OEM intakes are very well proven.
Even a thin metal intake will indeed last for a long time before it fails, as it would take a lot of cycles and pressure for the metal to fatigue.
But it is clear most people buy intakes for looks for their car rather than performance. They'll all make lots of power with ease anyway, so never worry about it.
Although I'd have preferred black myself. They are still a cool looking item.
Old Feb 7, 2017 | 01:12 AM
  #56
6point0 goat's Avatar
Wanted to bump this. Any other updates? Considering it for my TT application as well.
Old Feb 7, 2017 | 04:14 AM
  #57
If you like the look of it, buy it. If not, dont.
Old Feb 7, 2017 | 05:37 PM
  #58
I ran 20psi through it. Intake held up fine. Unfortunately the tune wasn't good.
Old Feb 7, 2017 | 05:56 PM
  #59
Jake the SSnake's Avatar
Ouch
Old Feb 7, 2017 | 06:09 PM
  #60
Block is at the machine shop getting decked. Balancing the stroker crank, heads are fucked so LSA heads are on the way. Should have it back together beginning of March.
