Holley Sniper intake review
The mod motor seems to work very well with it since it is only 300" and doesn't need a lot of cross section. Larger engines such as the LS need more cross section if you really want max effort power production.
Of course anything will work, just how well is another story...
So just how inadequate is it really ?
I dont know about runner size, but to me the plenum on the ProFlo is tiny, but then I'd assume Edelbrock did do testing of some description before coming to the size they used, as lets face it they could have made it any size.
The Chinese intakes are slightly different as you can be damn sure there was no testing. That said, they're making them a height that is more car friendly than the ProFlo or indeed the HiRam. So most wont care simply because it fits.
And as Alchemist alludes...although yes some of these intakes offer terrible results at the lower rpm's and mid range, simply because the engines already make a shitload, is it really an issue ? Probably not. Especially with a blower that is always forcing air in regardless.
Perhaps slightly more concern to those with turbos, as off boost performance is bound to be more noticeable, and perhaps it can even affect boost thresholds. Enough to really worry ? Again probably not.
Although another thread on this forum recently did seem to suggest the Sniper intakes do not use factory o-rings, and they use some shitty round ones which do not seal well.
Now that IS an issue.
Anything will work, how well it works is another story.
What I'm getting at is that an engine that makes a lot of power needs enough cross sectional area to make the most power possible. If you're using a manifold like a Pro Flo you're leaving easy power on the table.
When you have the proper area at the plenum, and at the MCSA is when the magic really starts to happen.
I used to have plenum entrance CSA and runner exit CSA on a lot of different intake manifolds where I used to work, but no longer have access to that information anymore.
I believe the exit CSA on the Pro Flow was like 2.6 in^2 IIRC. I couldn't get a snap gauge into the plenum to measure the entry unfortunately. Not only that, a lot of the manifolds out there don't have a continuous taper from plenum entry to runner exit. No bueno if you want to squeeze everything you can out of it.
Seems your not very hot on the Sniper. Do you have a favorite "budget" intake manifold for a relatively high RPM forced induction LS? I think I've seen you use single plane carb style intakes on a lot of builds?
I have been working very closely with John@CID in the real world R&D testing of his new BE LS single plane intake manifold and soon to be starting on real world R&D on his new power adder inline heads. I've probably sold more and cammed more of the BE intakes than anyone as of yet.
