CR for procharged LS1
Old May 23, 2016 | 08:51 PM
Firehawk173's Avatar
Default CR for procharged LS1
First build for me, and I am trying to figure out compression ratio before I pick new Pistons/rods. I have read in a lot of posts that you want some where in the 9.7-10:1 CR for a procharge build. Here is what I got.
Wiseco 3.903, -3.2 reliefs
LS9 gasket 4.100, .051 thickness
PRC 215 68cc
Stroke 3.622
CR: 9.64
Getting 9.92 with same stuff except a .041 gasket 4.0 size. Also thought about using Trick flow 220 that have a 64cc chamber, same piston and LS9 gasket. I am getting CR:10.08. I used the Wallace racing calculator and just wanted to know if those are correct CR numbers. Any advice on the Pistons or which head to go with would be great.
Thanks
Old May 24, 2016 | 09:24 AM
conan's Avatar
I get 9.635:1 compression with the LS9 gasket. I would shoot for 10:1 - 10.5:1 for a street driven Procharged car.
Old May 24, 2016 | 10:15 AM
handyandy496's Avatar
I have been reading threads about this also. It seems a lot of guys are going with high boost and low compression and having to spin the pro charger beyond its safe rpm speeds. There for to compete with a turbo build boost wise is not the way to go.
There are calculators that will take your horse power plus psi and give you a result. I was amazed to see a 550hp motor @ 7psi went to 800hp more or less. This made me think that a pro charger could last forever compared to turbos while making great power with better air temps and higher compression. Should be great out of the hole and at 1/8 mile tracks.
I also found that even a high compression engine to around 12:1 camed correctly bleeding off cylinder psi @ the right amount (overlap/lobe separation) is good. Pro chargers are ideal for stock cr's (11:1-10.5:1)and cams.
Old May 24, 2016 | 12:33 PM
Rise of the Phoenix's Avatar
OP, what octane fuel are you going to run? That's going to be the determining factor.
Old May 24, 2016 | 01:20 PM
Will be running 93. Still messing with piston and head combos to get that 10:1 ratio.
Old May 24, 2016 | 01:39 PM
Used diamond racing calculator and got a 10.15:1 with:
Wiseco 3.903, -3.2 Pistons
Scat I beam with arp 8740, 6.125", .927 pin
PRC 225 heads 62cc small bore chamber
LS9 head gasket
Any suggestions or changed I should look into?
Old May 24, 2016 | 02:52 PM
panic's Avatar
Neither of those affect DCR directly. The determinant is intake valve closing point.
Some of those computers are using this:
New HP = old HP X (boost + ATM)/ATM
Example: HP = 100 HP X (14.7 + 14.7)/14.7 = 200 HP
This is nonsense, and comes close only by accident.
Old May 24, 2016 | 03:13 PM
Mike 02T/A's Avatar
My car made 400 on motor and 650 w/ 10psi. I believe I ran out fuel pump because the chart almost flatlined at the top, didn't keep climbing. I only had the Aeromotive 340 stealth pump during my tune.
Old May 24, 2016 | 06:38 PM
I must be getting something wrong with my numbers. I see people posting getting 9.6-9.8 CR with -10 cc piston and 72cc heads. Am I doing something wrong? Have been using Wallace racing and diamond racing calculators. Also plan on using brute speed blower cam.
Old May 24, 2016 | 07:12 PM
Mike 02T/A's Avatar
My heads have been milled 2x, if you saw my thread. I was guessing they're 71 or 70 cc now instead of 72.
Old May 24, 2016 | 08:18 PM
I read through some of your thread, but you are running a 383 right?
Old May 24, 2016 | 08:26 PM
Thanks for the Info. I have decided on the scat I beams and Wiseco 3.905,-3.2 dish, LS9 gasket and prc 225 cc head with a 62cc chamber. Used diamond racing and Wallace racing calculator and got 10.2-10.3 CR with that setup.
Old May 24, 2016 | 09:06 PM
conan's Avatar
That will be nice to drive around out of boost and part throttle. D1 head unit ?
Old May 24, 2016 | 09:08 PM
Detoxx03's Avatar
For 93 octane 10.2:1 minimum.
Old May 25, 2016 | 06:19 AM
Yeah a D1 haven't decided FMIC or the twin 4.5 yet.
Old May 25, 2016 | 08:28 AM
Detoxx03's Avatar
FMIC is the only way to go
Old May 25, 2016 | 08:45 AM
conan's Avatar
X2
Old May 25, 2016 | 09:18 AM
Mike 02T/A's Avatar
Yes, it's the TMS 383.
Def go with the FMIC.
Old May 25, 2016 | 10:41 AM
I wouldn't use an off the shelf cam in a really good build like this. jmo.
Old May 25, 2016 | 12:11 PM
Thanks for the advice will call around when I get to that point.
