How much oil you running and what type?
Old Jun 5, 2016 | 05:26 PM
MoNoXSizzlE's Avatar
Default How much oil you running and what type?
Been doing a lot of reading on this subforum about oil. Seems a lot of you are running Rotella 15w40 and anywhere from 6.5 quarts to 7. I'm running a stock 5.3 with a 76 mm turbo & e85. Scavenge pump as well. I'm also in New Mexico so it's usually hot out where I'm at. Just looking for suggestions. Thanks in advance
Old Jun 5, 2016 | 05:36 PM
yenkomike's Avatar
I run rotella 15-40 I have ran t6 0w40 but just seem to have good luck with it.
Old Jun 5, 2016 | 07:35 PM
What is your setup? Also how many quarts are you running?
Old Jun 5, 2016 | 07:40 PM
coltboostin's Avatar
15-40w Rotella, in literally everything. 5.7, 6.0, 5.3 Mistus....Anything old, beat and turbo.
Old Jun 5, 2016 | 08:00 PM
That's what I'm hearing? Confused on quarts on how much. I just got my car running last night on a base tune. Have Mobil 1 5w30 5.5 quarts. Drove about 3 miles, oil pressure dropped off a lot. I'm thinking more oil will be needed now because of the newly added turbo and scavenge pump. Was thinking about flushing this fresh oil and just going with Rotella since it's being recommended a lot here. Just wondering how many quarts? 6.5-7?
Old Jun 5, 2016 | 08:08 PM
3 window's Avatar
What pan? I'd be concerned with the oil pressure drop. How much is "a lot?"
Old Jun 5, 2016 | 08:36 PM
I'm running a ported ls6 pump from TSP. Drove it to the shop and it was maxed out, thought the reader was broken. After I got a base tune it dipped to 1/4 pressure. Checked dipstick, showed low oil about 1 quart. Running 5.5
Edit: running stock ls1 pan
Old Jun 5, 2016 | 08:46 PM
dburt86's Avatar
i run 7 qts in a fbody pan with 20-50
Old Jun 5, 2016 | 08:52 PM
3 window's Avatar
I'd run 7 qts. Put a manual gauge on the car and get an actual pressure and go from there.
Old Jun 5, 2016 | 09:16 PM
Thank you guys for the info, saviors! You think I should flush this 5w30 Mobil 1? Has only 10-15 miles on it and just run Rotella? Also do you have a link on what gauge I should get? I just picked up a 3 pillar pod and only have an AEM AFR on it now
Old Jun 5, 2016 | 09:24 PM
3 window's Avatar
Any gauge would work. Could even be a temporary gauge just to check. Check it with the oil you have now, then change the oil and make sure there's no copper in it or the filter. Then go Rotella and recheck your pressure.
Old Jun 6, 2016 | 12:09 AM
Btw, what filter do you run with Rotella?
Old Jun 6, 2016 | 12:41 AM
badchkn13's Avatar
Rotella 15/40
7.5
Fbody pan
K&n oil filter
Old Jun 6, 2016 | 01:36 AM
gccasper04's Avatar
Rotella 15-40. 7qts ls1 oil pan here
Old Jun 6, 2016 | 01:40 AM
Blown06's Avatar
8 Second Truck Club
I use a truck pan, so don't have pick up issues.
6 qts, usually 20w50 Valvoline VR1 then will move to a same wt full synthetic once the motor has had the **** beat out of it (usually a few passes).
Old Jun 6, 2016 | 05:33 AM
yenkomike's Avatar
I run the gm musclecar pan. little over 6 qts to full line.m295 oil pump ,idles at 40 psi hot
Old Jun 6, 2016 | 06:24 AM
dburt86's Avatar
Just be careful running the rotella (or any heavier oil) because alot of those oils are for diesels.
They can be identified by the stamp on the back. Diesel oil will start with a C (for combustion ignition) and gasoline oil will start with a S (for spark ignition)
Or something like that.
I guess the detergents are very different. Ive ran both in gas engines before with no issues, but its just as easy to get the right oil.
Old Jun 6, 2016 | 11:56 AM
I'm also assuming you're running Rotella synthetic as well?
Old Jun 6, 2016 | 11:58 AM
dburt86's Avatar
Im running the napa brand, which i think is valvoline
Old Jun 6, 2016 | 12:05 PM
LS6427's Avatar
Funny...out of all the people I know with LSx engines, or Fords or any other muscle car makes since 1998 (18 years) since I bought my 1998 WS6...maybe a good 50 personal friends or acquaintances over the years at gatherings and car shows......not a single person with a well built stroked/bored engine or boosted engine ever got close to 100,000 miles without having to rebuild it, or whos engine has let go for some reason or another and grenaded.
They all use expensive synthetic oils.........
I have never used anything but the cheapest off the shelf Castrol GTX $2.99 quart oil. My engine made 173,000 miles....and never burned oil along the way.
I always used 5 1/2 quarts....15w20 only.
