turbo 5.3 heads queation
Old Jun 8, 2016 | 04:44 PM
jacobrobertson2010's Avatar
Default turbo 5.3 heads queation
Hey guys. I'm at a cross road. I have a set of prc 225 as-cast 62cc heads. Intake setup is super vic. Would it be OK to run thesee heads on the 5.3 or run some stock heads. I know they are a little big for that bore. What yall think? Turbo is t4 s475, 87 turbine, 1.10 AR. Thanks
Old Jun 8, 2016 | 11:34 PM
1FastBrick's Avatar
Try waiting more than 3 hours and 18 minutes between post...
According to PRC specs they have a 2.06 intake valve. I am not sure that will clear on 5.3L bore.
You're probally best to stick with a stock casting.
Old Jun 9, 2016 | 09:02 AM
1CAMWNDR's Avatar
Stock heads. Good valves and valve job. Late model 5.3 heads are the same as LS6 heads.
Old Jun 9, 2016 | 09:17 AM
roastin240's Avatar
Does anyone know if there are issues with valve shrowding with larger bore heads on a smaller bore engine?
For example - 317 heads on a 4.8 or 5.3 bore (3.78 in)???
Old Jun 9, 2016 | 01:27 PM
That's what I was worried about. Texas speed said there would be some showing. They said they will work. But not optimal. Just seeing what yall think. I hate to not use some decent heads that I already have
Old Jun 9, 2016 | 01:31 PM
JoeNova's Avatar
Restricted User
They used the 2" intake valve on the 3.78" bore for a HUGE amount of production engines. I would say its fine.
Old Jun 9, 2016 | 01:32 PM
1FastBrick's Avatar
On a Flow bench, They start to shroud around 2 inch on the 4.8/5.3L bore.
On a wheel dyno it showed like a 5hp loss with the larger valve below 2000-2500 put above that the larger intake valve gained it back.
But being forced induction I don't think you will have anything to worry about.
Old Jun 9, 2016 | 09:57 PM
Thanks. I guess I'm going to bolt them on and see what they do
