Ring gap for boost
Old Jun 12, 2016 | 07:50 AM
BS2011's Avatar
Default Ring gap for boost
Ok guys I have a 408 that I was going N/A with, but I came across a turbo kit at a good deal. My question is will my ring gap be ok with boost. Engine specs are: 408 with callies dragonslayer crank, callies billet rods, ported and polished 317s with cometic gaskets, and head studs and main studs, wiesco pistons flat tops with valve reliefs top ring on 19 bottom ring on 21. Engine is together and ready to go, but its not in the car yet, Let me know what you guys think. thanks
Old Jun 12, 2016 | 08:03 AM
Taxman20's Avatar
You should open the gaps. Maybe around 26-28 on the top ring. Also what's your compression? Turbos don't like a lot and its best to be around 10-1 or less. Some people run higher.
I am building mine now so I am also learning and have done a lot of research so far.
Old Jun 12, 2016 | 08:24 AM
BS2011's Avatar
Brian tooley ran my numbers for my custom cam which is a turbo cam to help with the compression it's built to drop the cylinder pressure. With that being said it's 10.7 is what he came up with. I will also be on e85
Old Jun 12, 2016 | 10:46 AM
conan's Avatar
I have my total seal rings gap at .021 top and .023 bottom. 10.1:1 compression 91 octane / meth injection 8#'s of boost.
Old Jun 12, 2016 | 12:19 PM
BS2011's Avatar
I know this subject has been beat to death, but I'm trying not to build a bomb haha. I hope some more experienced people will chime in.
Old Jun 12, 2016 | 03:12 PM
SteenH's Avatar
Rings are one of the only things that the bigger the gap, the better I feel.
Old Jun 12, 2016 | 03:28 PM
STAR's Avatar
.024" top
.028" bottom
Old Jun 12, 2016 | 03:31 PM
gtfoxy's Avatar
Pump, pump/alchy/water & race gas all benefit from different gaps.
Turbo motors that I've built I run the 25-28 for the top & I tighten the second up to about 18-20.
Old Jun 12, 2016 | 06:40 PM
BS2011's Avatar
Thanks for the info guys keep it coming.
Old Jun 12, 2016 | 08:02 PM
truckdoug's Avatar
TWSS
Old Jun 13, 2016 | 05:56 PM
stevieturbo's Avatar
You'll never **** up an engine because of too big ring gaps.... ( well unless you get silly with them )
Are your pistons designed with boost in mind ?
How much boost do you expect to use ? What fuel ?
Old Jun 14, 2016 | 08:19 AM
BS2011's Avatar
Boost wise anywhere from 15 to 20lbs and it will be on e85. I have wiseco flat tops with valve reliefs. I'm just trying to make sure I'm not going to blow the tops of the pistons off. lol
Old Jun 14, 2016 | 09:59 AM
And that doesnt answer if the pistons were designed with boost in mind.
Old Jun 14, 2016 | 12:24 PM
BS2011's Avatar
the pistons are forged wiseco -3 flat tops with valve reliefs. Top ring is on 19 and the bottom is on 21.
Old Jun 14, 2016 | 12:45 PM
Taxman20's Avatar
Pistons are designed to be uses as NA or Nitrous or Blower/turbo type. That's what they are asking for.
Old Jun 14, 2016 | 12:48 PM
alocker's Avatar
I went 24-26 on my SBE LY6 with 17 PSI on E85 and it is holding up so far.
