Pining the crank really neccesary?
Also if anybody has a spare 99-92mm dbc tb they would let go cheap I could use it
Thanks for any help!
There is a good reason that pinning kits come with all s/c kits for these cars. If the balancer slips and there's a good chance that it will, it will chew up the snout on the crankshaft and then you will not be able to get a new balancer on tight and straight. May end up needing new crank, I have seen one spin and the aftermath.
You can find used kits on the classified section or maybe on ebay from time to time. The pins and the drill bits are standard hardware store type stuff. If you have to get a kit, you could probably resell it later.
That makes a lot of sense now. I didn't realize how much stress/resistance the S/C put on the crank/balancer. I appreciate the info!
How do you like your MP112?
This wasn't the front pinning tool-prob. a bunch of the tools floating around after someone used them, just need a pin or cut a 1/4 bolt as a replacement.
Then replace the bolt with a new one, and torq.
Thankfully, when I decided to get back to a complete revamping of, and completion of my build, which is still inwork but moving forward nicely, my better machine shop here in Cali was able to turn down the crank snout but we had to special order a new Damper hub from ATI that was slightly smaller inside diameter at a mere cost to me of over $600 including the crank snout and double keys machined in instead of pinning.
Pin that sucker. And if someone else does it for you, verify it.
Lesson learned.
Makes me curious now out the LSA and the LS9 that are supercharged. Are they keyed/pinned form the factory?
I agree with that 100%. Was just stating that I don't see the reason it should cost so much. I also agree that it's better to learn here rather than learning when you have a failure.
